Today went out for a quick activation of bearby CT/MN-054, before Easter duties. To speed things up, I took the QRPLabs QDX digital transceiver QDX and also a QCX mini, for CW ops.
I now have two logs, one from WSJTX, with the digital contacts, and a second one, on VK-port-a-log, for the CW qso´s.
As some might know, WSJTX´s ADIF does not have a SOTA field.
So, is there an utility out there that would allow me to add the SOTA reference to the WSJTX log and also allow a merge with the VK-port-a-log?
Otherwise, all I can think off is to fire up Fast Log Entry (FLE) and doing it all by hand.
Thank you both M1EYP and M0WIV, I lookd up both of your suggestions and figured out that ADIFMaster was the one app that took care of adding the SOTA field and merging both ADIF logs.
