perhaps someone can help and im sure it would be useful info for someone else too
i recently purchased an ft-817ND
but when programming Wide 7.6MHz Repeater shifts using FT-817 Commander i cannot seem to get the shift to work (i.e it doesnt put a shift in even though its set as a shift in the software)
when i program it to memory as a split Frequencey in FT-817 Commander when the PTT is pressed i get TX Err
when entering it all manually on the radio it works fine and the 7.6MHz split also works
now i really am puzzled it works manually but doesnt programmed via the pc into a memory
i suppose its not to difficult going through manually to set it but then when i reload the memories through ft-817 commander its going to muck it all up again
Well My sunday roast is ready so i better go eat it hihi
I tried to program 430 RX with a plus 7.6MHz shift and Commander locked up. Twice! The 817 display was blank and it wouldn’t power up till I pulled the data lead. After the second lock up I decided that as my 817 was working discretion was the better part of valour.
I’ve had similar issues with my FT-817ND and MacMemoriesManager, so I suspect there’s something about the 817’s CAT chit-chat that doesn’t quite do what’s expected of it.
I used to use FT817 Commander for this and don’t recall ever having a problem with 7.6MHz shifts. I now use FTBasicMMO because of its superior import/export facilities, and definitely don’t have a problem.
AFAIK there is no fully documented (by Yaesu) way of programming the memories over the serial interface; there’s a certain amount of reverse engineering of the EEPROM format in all of this. The FT-817 and FT-817ND need some slightly different tricks (FTBasicMMO needs to be told which you’re using).
Unfortunately the trial version of FTBasicMMO doesn’t let you try out the critical bit of actually programming your radio, even during the evaluation period. But it’s not terribly expensive and I decided it was worth the risk; it certainly works for me and has saved me a lot of time.
BTW, FTBasicMMO does not use the CAT protocol, but uses clone mode to programme the memories en masse. This seems more reliable.
Something like that might well explain the strangeness I saw, as the program only knows about “FT-817” and so could well be tripping over whatever the differences between the old 817 and the newer 817ND are…
