Hi Folks, I’ve got lucky having an older Yaesu FT-1000 (not quite ‘D’ although having few extras) on loan for couple of weeks. I’ve immediatelly liked its receiver, which appeared to be quite better than in my TS-870s (especially in CW), also 200W of output power makes noticeable difference too. The TRX used to serve as a contest rig for several years and now I have an opportunity to buy it.
The problem I have is, although I generally favor older rigs over modern TRXes and fairly confident with a soldering iron and repair basics, this particular TRX has few issues which puts my decision making on hold.
The first issue I’ve encountered was a not working attenuator. The issue was in three burnt resistors in the RF Unit. That I’ve successfully resolved.
Another issue is with a memory encoder knob, memory channels are not switching over. After some investigation it appeared that the actual encoder is faulty and needs to be replaced. The only place to get those now-a-days is a second hand market, no new parts available anymore.
And finaly a third issue is quite a dim display. While in a darker room it looks okay, during a day it is quite diffucult to take readings. Dim button makes readings virtually unreadable during a day.
Also, the rig was modded significantly. That, perhaps, is ok or even great, however most of us aware that an imrovement in one place could cause a degradation elsewhere. So certain uncertainity exists once it was done not by myself :).
So, what would yous think? Older, top of the range back then and probably still adequate FT-1000 with some issues or stick with also fairly old, but reliable with no issues mid-ranger TS-870s ? ![]()
My style of operation is mostly CW, chasing DX and CQ. No stranger to Digi modes, but very rarely working SSB. I have couple of days left to make a decision so greatly appreciate any input ![]()
73 de EI4JY, Alex
