FLEcli is great!
I wanted to give a shout out to @ON4KJM and his excellent program FLEcli:
If you have ever used DB3CB’s ‘Fast Log Entry’ (FLE) program, you know how fast and efficient it is for capturing paper SOTA logs. The FLE ‘shorthand’ for entering logs is exactly how I write my paper logs. The only problem is that FLE only runs on Windows and I (and many others) use other operating systems like Linux or MacOS.
FLEcli has solved this problem. I can now enter my paper activation logs using any text editor and then run FLEcli to produce a CSV file that I upload to the SOTA DB. So quick and easy, and works on every computer I own including the Raspberry Pi.
Thanks for a great program Jean-Marc!
-Josh WU7H
