Kai, DL3HAH and I will be airing at least 20 summits in France/low Vosges (FL/VO-xxx) from Aug 20 thru 25, 2023 running QRP mainly on 40/30/20m CW. Rig: IC-705/w 10 watts, EFRW. Listen for F/DL3HAH/P and F/DL1HBT/p and check SOTAwatch or SOTL.AS. Alerts to follow as activation period comes closer. NB: Our base camp will be in Oderen… vy73/55, Tom
Viel Erfolg und hoffe auf den einen oder anderen complete,
Paul DL6FBK
Moin, viel Spaß dabei. Ich war heute auf FL/VO-003. Eine der schönsten Touren der letzten Jahre, eine unbedingte Empfehlung!
73 de Alexander, DL1AIW.
Hallo Alexander, das hört sich ermutigend an… ich werde das bei der Touren-Planung berücksichtigen vy73/55, Tom
Paul, das kriegen wir hin… hast Du eine Liste derjenigen FL/VO-xxx die Du aktiviert hast? Ich würde dann das Ziel “Paul-complete” mit in die Touren-Planung einfließen lassen vy73/55, Tom
I’ve only recently returned from a trip that included several days staying in Urbès, just 3 or 4 km south west of Oderen.
Not sure if you have been there before, or what your accomodation will be? I have some basic non walking/non SOTA logistical local knowledge I can share if desired.
I intendend to do writeups for the summits I completed, including track logs for those that are not trivial simple “drive up” type. You can check which ones I did on my log in the SOTA Database for now. Most have many many activations and are very simple to do, but if there is any specific information please ask.
Superb area! I hope you get the WX that I experienced (apart from the 1 thunderstorm while activating!).
Gerald, neither Kai nor I have been in the greater Oderen area before, but Kai is pretty experienced as far as vacation in France is concerned. So he was the one to book our accomodation, which is a small house on the outskirts of Oderen (do not have the details at hand right now).
We are looking forward to your stories and are grateful for any hints you can give that my havbe impact on the tour data. I will come up with the tour details in early August 2023 I suppose, maybe you can share insights on one or the other summit. vy73/55, Tom
Danke Tom, die Liste kann ich dir gerne liefern:
FL/VO.007, 011, 022,025,027,028,030,032, 085, 173
Besten Dank, awdh und 73,
Paul DL6FBK
Prima, Paul…stehen schon mal auf der Merkliste
vy73/55, Tom
Plans become clearer as our activation windows comes closer. I have compiled the following list of 30+ summits, of which we will be visiting at least 25.
summit | coordinates (Breite, Länge) | distance from Oderen [km] |
FL/VO-008 (Tête de Fellering) | 47.91,6.9288 | 9 |
FL/VO-087 (Haut de Brampas) | 47.9172,6.902 | 10 |
FL/VO-012 (L’Altenberg) | 47.9919,6.9441 | 14 |
FL/VO-013 (Rossberg) | 47.8209,7.0092 | 16 |
FL/VO-169 (Karsprung) | 47.8504,7.0994 | 16 |
FL/VO-010 (Le Grand Ventron) | 47.9596,6.9253 | 20 |
FL/VO-084 (Ronde Tête) | 48.0003,6.9613 | 20 |
FL/VO-085 (Tête des Corbeaux) | 47.9013,6.8491 | 20 |
FL/VO-080 (Rothenbachkopf) | 48.0008,6.981 | 21 |
FL/VO-018 (Haut du Rouge Gazon) | 47.9236,6.8539 | 22 |
FL/VO-006 (Tête des Neufs Bois) | 47.8717,6.9096 | 23 |
FL/VO-083 (Grand Artimont) | 48.0255,6.9803 | 23 |
FL/VO-017 (Le Molkenrain) | 47.854,7.1299 | 24 |
FL/VO-078 (Le Storkenkopf) | 47.905,7.0821 | 25 |
FL/VO-001 (Le Grand Ballon de Guebwiller) | 47.9009,7.0984 | 28 |
FL/VO-005 (Ballon d’Alsace) | 47.8223,6.8451 | 29 |
FL/VO-088 (Le Faing Berret) | 47.9802,6.8547 | 29 |
FL/VO-177 (Haut de Felzach) | 47.9308,6.9258 | 29 |
FL/VO-081 (Le Lauchenkopf) | 47.9562,7.0393 | 30 |
FL/VO-004 (Le Gresson) | 47.8462,6.9117 | 31 |
FL/VO-011 (Sommet de Belle Hutte) | 48.0372,6.9514 | 31 |
FL/VO-015 (Tête de Grouvelin) | 48.0467,6.9169 | 31 |
FL/VO-066 (Le Rondfaing) | 47.9969,6.8242 | 31 |
FL/VO-170 (Le Rainkopf) | 48.0097,6.9827 | 33 |
FL/VO-030 (Tête du Midi) | 47.927,6.7877 | 34 |
FL/VO-067 (Haut du Roc) | 47.9789,6.7769 | 34 |
FL/VO-079 (Klintzkopf) | 47.9497,7.0558 | 35 |
FL/VO-009 (Ballon de Servance) | 47.8296,6.7928 | 40 |
FL/VO-168 (Rimbachkopf ) | 47.8511,6.9395 | 40 |
FL/VO-172 (Dornsilkopf) | 47.9726,7.1537 | 42 |
FL/VO-082 (Petit Ballon) | 47.9807,7.1261 | 45 |
If we can help you achieve “completes”, let me know… we will try to be as supportive as possible… as long as we do not have to make SSB nor FT8
vy73/55, Tom
Hallo
Oderen liegt klasse für ein solches Event.
Ich habe euch mal meine Aktivierungsliste der 20 Jahre Challenge (die leider noch nicht ausgewertet ist) angehängt. Dann habt ihr eine Idee, was man gut kombinieren kann. Neben den Bergen im Schwarzwald habe ich auch die Vogesen besucht. Dabei habe ich auf Fahrzeiten und Laufzeiten geachtet.
Der einzige für mich interessante Summit um einen complete zu erreichen, wäre der Karsprung FL/VO-169. Aber der liegt abseits und ist ist für euer Vorhaben nicht so klasse.
Viel Spaß und hoffentlich gutes Wetter
Moin Armin,
super, das hilft uns sehr…vielen Dank. Wir schauen vor Ort noch einmal nach, ob wir unseren Einzugsbereich vergrößern oder verlagern, auf diese Weise ist dann die Schnittmenge “complete” für Dich wieder etwas größer… ich melde mich!
cu, Tom
Alles klar Tom
Wenn du fragen hast… zum Parken… zum eventuell hochfahren (4x4 ?) … melde dich einfach… ich kenne mich ganz gut aus und es ist bei weitem nicht alles dokumentiert.
Wenn du magst, stelle ich dir gern auch Kombinationen von summits zusammen. Aber ich denke, dass macht solch einen Spaß und solche Vorfreude, dass willst du selbst machen
Tolles Angebot, Armin…danke dafür. Zur “last minute” Validierung der Tourenplanung komme ich vielleicht tatsächlich noch mal auf Dich zu… Ansonsten sehe ich es wie Du: Die Planung ist schon ein aufmunternder und schöner Teil der SOTA-Aktivierung, den macht man besser bis zu einem gewissen Punkt allein
Hallo Armin,
die Planung schreitet voran… wenn Du magst, sende ich sie Dir gerne zu (EMail-Adresse?). Wenn Du Lust und (!) Zeit hast, bin ich für Hinweise sehr dankbar. Bei ein paar Hügeln fehlen mir geeignete “Absprungpunkte”, die vorhandenen SOTA-Tracks waren hier irgendwie nicht das was ich suche und Jarek (SP9MA) hat auf meine Anfrage vor einigen Wochen leider nicht reagiert
Kai bringt mich am 26.08.2023 wieder nach Mannheim zum Zug, vielleicht treffen wir uns in Freiburg auf einen Kaffee? Meine Mobilnummer lautet: +49 151 2279 4005
vy73/55,Tom
