Well - Inspired by Mike YYY( Who else?) I decided yesterday to make up a simple dipole for the 10m band.
Today, I took it up my local hill to try it out - quite expecting to spend most of my time trimming etc. but no, it was perfect from the word go!
Finding that it was resonant at the point I wanted to operate I duly called CQ.
Mike TUH was in the log. Mike kindly spotted me and put me on the DX cluster - thanks Mike. After the spot things started to happen fast and in just 1 hour 26 minutes I made 51 contacts all on 28mhz.
Hello Barry
Could hear you for over 20 minutes via the ground wave 5/1, sounded really echoey. Did turn the Yagi to check for back scatter but found none so must conclude it was ground wave propagation over this short distance. Thanks for the contact!
73 de Phil ON4TA
Funny you mention echo-like sounds on a ground wave contact. Last weekend I had very short skip contact on 20m (Leeds-Tyndrum) about 350km. The signal was not loud but being on a summit meant there was no QRM etc. So I could hear a signal at 31 but it was very “watery” or “shimmery”. At times there was a distinct reverb if not echo. Obviously multiple paths bot only having a vertical I couldn’t check for directions for direct and reflect rays but possibly a mix of ground and sky wave.
Thanks for the S2S today. The 10m bug bit me yesterday, with the arrival of the new FT-817ND on Friday I could not resist it.
First SSB and first 10m activation…
Mild Wx at Walton hill this afternoon, 8C and some sun spells.
The antenna was a littte bit of a compromise on 10m… a 20m EFHW/MT – twicked with a T1. . I took my VK5JST aerial analyser to check what was going on .
(in hindsight my 9m randon wire and 9:1 unun / T1 would have been better I think)
I logged in 16 QSOs in 30min
9 on 10m
7 on 20m
2 cw
3 DX on NA
1S2S
The only disturbance were the numerous dogs, I almost had to “administer” one of them that jumped over my gear as I was responding to Manuel EA2DT.
It was great to work 10m/SSB for the first time as well as my friend Ignacio EA2BD. Many Thanks to all the Chasers.
