First activation of Großvenediger (OE/TI-003, 3666 m)
Due to the high altitude this summit can only be accessed by crossing a glacier, while trying to avoid closer contact with crevasses. We started at 5 o‘ clock in the morning from the Kürsinger hut and reached the summit after about six hours. Being part of a rope team, we had to adjust our hiking speed and the time slot for the activation.
At first we thought we could also operate on 14 Mhz, but conditions did not allow it. The weather was fine but rather cold and windy and we only had 15 minutes operating time while we were queuing to cross over to the tiny summit area.
We, therefore, only operated on 2m FM and then headed downhill. On the way up we had walked over several snow covered crevasses. If we had stayed much longer on top the sun would have started to melt the snow bridges across the crevasses and the risk would have been much higher.
We are very sorry, but we had to cancel the 14 MHz alert even though some of you chasers might have been waiting for a spot.
See you next time
Sylvia, OE5YYN and Peter, OE5AUL
