F8AJY/P : SOTA / SSTV
Good evening,
I am posting this message because tomorrow, Saturday, October 31, 2026—weather permitting—I plan to activate 3 SOTA (Summits on the Air) summits using QRP (low-power) equipment.
In addition to CW and SSB, I intend to transmit via SSTV (Slow-Scan TV).
The specific times and modes will be posted on SOTAwatch.
Please note, however, that given my setup—a 10-meter mast (or a tall tree) and a home-built EFHW (End-Fed Half-Wave) antenna—it is quite possible that I may not be able to receive your signals.
Conversely, with your fixed station equipment, it is very likely that you will be able to receive mine.
I would be very interested if you could post any images you manage to receive, even if a two-way contact is not successfully established.
The purpose of this “request” is to help me gauge the “reach” and signal quality at that specific moment. Furthermore, this is my first time attempting such an experiment within the SOTA framework.
Thank you very much in advance.
Best 73s
Xavier F8AJY
Good evening everyone,
I’m taking a moment to write a quick post.
My SSTV trials during this SOTA activation didn’t go as planned…
Perhaps it was the weather, the propagation, my 5 watts, or the forest—in short, it was just a test.
I’m not letting this setback stop me.
I’ll try again on a future outing, perhaps focusing more on SSTV rather than CW or SSB.
SOTA is truly fantastic—it combines hiking with amateur radio.
And the best part is that when you turn on your rig, you never know which country might answer you…
it’s always a wonderful surprise!
Best 73’S Xavier F8AJY
Hi Xavier,
If you haven’t already seen, there are some websites that monitor SSTV frequencies and show any received images to check if you are being picked up: https://www.worldsstv.com/
If you want to test your software, the ISS is transmitting images on 70cm for the next few days. You should be able to pick it up on the Quansheng with that antenna as it uses a decent power.
You can use the Look4Sat or Robot36 Android app if you don’t have a cable to connect the HT to a laptop.
Good evening Pete,
Thanks for your reply.
I wasn’t aware of this site:
I’ll take a look.
I’ve conducted some tests on HF—on the 20m and 40m bands, among others—transmitting images in Robot 36 mode using my smartphone.
However, I didn’t get any responses… perhaps it’s due to what I mentioned in my earlier post—I’m not sure.
The goal of these tests was to transmit photos from various SOTA (Summits on the Air) activation sites.
As for the ISS, I’ve also been trying to receive signals using my UVK5 handheld radio; it works quite well when the sky is clear. Attached is an image I received on November 9, 2026, via UHF, from the “ARISS Serie_35 Space Memories” collection.
Thanks again.
Looking forward to connecting again.
Best 73s,
Xavier F8AJY
