Database error? Not possible to spot
database working again … thanks!
The DB was offline from about 750 to 850. When this happens on a Saturday morning towards the end of the month, it is usually the hosting company applying Windows update patches and rebooting the server. As such, I normally allow extra time time before I report the fault as it probably isn’t a real outage.
It looks fine now.
Thank you very much Andy - website seems to be responding more quickly now to summit info pages and the SOTA Cluster is all good. Much appreciated.
Phil
I often think these things are your brain playing tricks, but it did seem that the DB was running a bit slow the last few days. The problem with it being on a shared server is you don’t know if it’s just someone else “eating all the pies” or something with your own instance or somthing with the server.
So a reboot will have flushed out all the tubes and so the data can flow swifter!
