Hello Filipe,
The best way to tell your project activating F/MC-189,
is to set an alert:
On the main page of sotawatch3, just clic on the “ALERT” button and set the call,reference, utc time.
And if you use CW, the system will “spot” you automatic.
73 and good activation.
Gerald F6HBI
Fine job Filipe,
As you have put an alert, you have been spotted by the system with help of RNB.
Question: What is this “Lionite” batteries pack?
The keyer is a bit heavy for climbing… but you are joung and healthy, so must not be a problem! hi…
73 and good luck for the next activations.
Gerald F6HBI
Yes the key is very heavy! The last time to mount the puy de st romain by the bad side it was a struggle, but I also took my CANON 600D and a tripod for the beautiful timelapse from there heheh
Hello again,
About the weight, the bencher + camera + tripod + Lionite bank (700gr) + FT817.
You have not choosen the easy way.
Thanks for the links (keyer and power bank).
73 from Gerald.
