F4CPJ
2 August 2021 14:30
1
On July 21 and 29 I went for a walk on the peaks of Mont Blanc and Mont Blanc du Tacul.
Like the previous faith for the AB-001 I arrived before the propagation and for the AB-003 I arrived later, I had the chance to make contacts.
Sunrise near 6H00 local, 1 hour after my arrival
Txing 1hour 2 contact
It was too cold I stayed 3 hours at the top so I had to go down. Ciao Mont-Blanc AB-001see you next year
near 08:00 UTC for more propagation ?
Now a lot of picture of AB-003, the snow rises with the wind near the summit
A little glance towards Mont-Blanc from the SOTA AB-003
The summit AB-003 Mont-Blanc du Tacul
Many thinks, good SOTA
73 jean-Sébastien F4CPJ
EA2IF
2 August 2021 14:52
2
Félicitations, Jean-Sébastien, pour ces deux super-sommets.
Câest domage quâil nây avait pas des chaseurs, mais oui, les conditions de propagation sont complĂštement fermĂ©es trĂšs tĂŽt dans le matin. Sauf, peut-ĂȘtre pour DX avec VK-ZL.
Tel expédition devrait avoir été bien publicitée et annoncée dans le Reflector. Je ne savais rien et je suppose que la plus part du monde pareil.
Assure-toi de bien annoncer ta prochaine expedition sur ce moyen du Reflector SOTA pour voir sâil est possible de tâassurer au moins quelques chaseurs.
Congratulations, Jean-Sébastien, for these two super-summits.
Itâs a shame that there were not chasers, but yes, the propagation conditions are totally closed very early in the morning. Except for VK-ZL, perhaps.
Such expedition should have been well advertised and announced on the Reflector. I didnât know anything and I guess it will be the same for most of the rest.
Make sure you will announce your next expedition on this Reflector SOTA to see if itâs possible to assure at least some chasers.
Guru
PA9CW
2 August 2021 15:04
3
Nice job. You can be vy proud that you reached the Mont-Blanc top!
Last year we also took a shot. Unfortunately too much stone in Goûter-couloir. So the attempt was canceled. Back to the hut.
73 - Tonnie - PA9CW
F6HHK
3 August 2021 16:23
4
Félicitations Jean Sébastien,
Un 4000 de plus au tableau du SOTA, voilĂ 10 points bien mĂ©ritĂ©s ⊠on attend la suite avec impatienceâŠ
Meme si la mĂ©tĂ©o conditionne parfois au dernier moment le âsummit dayâ nâhĂ©site pas a faire de la pub tres en amont sur le Reflector SOTA de tes tentatives : il vaut mieux annuler au dernier moment un sommet, plutĂŽt que lâannoncer trop tard. Câest lâactivateur le maitre des horloges ! ( et puis pour un chasseur câest beaucoup plus facile de se recoucher que pour activateur de gravir le sommet )
En tous cas bravo pour ces magnifiques sommets.
73 de Bruno F6HHK,
SOTA region manager F/AB
Congratulations for such high altitude activations.
What a pitty that only two chasers came back to the highest peak of the alps. Kudos to Lars @SA4BLM and Kyriakos @SV1RVJ for being early birds.
Which route did you take? What was the acclimatization procedure?
73 Joe
LZ2AF
6 August 2021 13:48
7
Respect!
73 de Rumen / LZ2AF
M0TKF
6 August 2021 15:13
8
Yes - what Guru said. Please advertise your mission in advance. I would definitely make an effort to be on air 04:00 or whenever to support a mountaineering effort.
Fabulous photos
F5ODQ
7 August 2021 06:33
9
Cela mâa rappelĂ© des bons souvenirs en voyant le sommet du Mont Blanc du Tacul ou je me trouvais il y a quelques annĂ©es.
CâĂ©tait super de te contacter en S2S depuis les PyrĂ©nĂ©esâŠ
Au prochain S2S
Alain
F4CPJ
8 August 2021 07:17
10
Hello Joe,
I took the normal route âmore easyâ :
Aiguille du Gouter, Dome du Gouter, Vallot Shelters and Summit.
For general acclimatization it is recommended to spend 2-3 days at more than 3800 before if you want not to be too bothered by mountain sickness.
F4CPJ
8 August 2021 07:22
11
Hello Tonnie,
I was lucky, it had snowed shortly before and the stone corridor was very safe !
I think you can try your luck again
73 Jean-Sébastien
F4CPJ
8 August 2021 07:29
12
Hello GURU,
Thank you for your message,
As soon as I had a night at the snack hut, I posted the message on the sotawatch, that is to say the day before. Itâs pretty hard to be able to access the refuge and the summit too unless you book a long time before and success is more random.
73 Jean-Sébastien F4CPJ
F4CPJ
8 August 2021 07:32
13
Bonjour Alain
Tout le plaisir est pour moi,
Peut-ĂȘtre un S2S depuis le Mont-Maudit ou le Mont-Blanc ?
je pense lâannĂ©e prochaine depuis le AB-001 en milieu de matinĂ©e ?
A bientot 73 Jean-Sébastien
