Hello
Just had a strange error when uploading my log from today. Every time I tried to upload a S2S with Bill G4WSB/P it said that there was there was …Error on Line 26: Incorrect summit format in column 10
I have looked at the CSV ( generated by Log4OM and I can’t see an error…( the top line is line 26)
V2,G4IPB/P,G/NP-023,11/10/2020,1032,3.738MHz,SSB,G4WSB/P,G/SC-010
V2,G4IPB/P,G/NP-023,11/10/2020,1043,145.575MHz,FM,M0YCJ/P,G /LD-011
Also tried with an ADIF file. Both took the first S2S ( With M1HAX ) but didn’t seem to like the others.
So, tried a work around and tried manually to enter the QSO and got the message below. I have tried this about five times so either I am making the same mistake or…???.. ( Tried entering as activator manually )
An error occurred while uploading your activation: SQLSTATE[HY000]: General error: 20018 Violation of UNIQUE KEY constraint ‘IX_Activations_1’. Cannot insert duplicate key in object ‘dbo.Activations’. The duplicate key value is (9888, Oct 11 2020 12:00AM, 1351). [20018] (severity 14) [INSERT INTO Activations(UserID, OwnCallsign, SummitID, ActivationDate, Points, BonusPoints) VALUES (9888, ‘G4IPB’, 1351, ‘11/Oct/2020 00:00’, 0, 0)]
Help!
( Browsers tried:- Firefox and Edge - system W10 )
Paul
