Error in special callsign EG5GURU/P on March 25, 23
In the Sota activation of March 25 of the Memorial Guru, ref EA5/CS-014 and in the spots corresponding to the calls in 14 and 10 Mhz, EA5GURU/P has been entered by mistake, being EG5GURU/P the correct one, please correct it in your logs , thanks for that.
EA4DOS, Elena.
En la activacion Sota del dia 25 de Marzo, del Memorial Guru, ref EA5/CS-0145 y en los spots correspondientes a las llamadas en 14 y 10 Mhz, se ha puesto por error EA5GURU/P, siendo lo correcto EG5GURU/P, por favor corrijanlo en sus logs, gracias por ello.
EA4DOS, Elena.
