On a recent activation in the DM/BM area and after 100s of activations, I noticed the BNC connector on my KX3 had loosened itself causing intermittent high SWR. The nut (something close to 11mm) required two full turns to tighten it against the conductive pad inside the case. One of the plug in boards had to be removed to obtain access for the spanner.
73 Phil
