I didn’t want to write a report of my activation today as I am coming to the end of a holiday here in Tenerife with my wife and time is short now, however I feel I ought to write something due to the standard of operating by certain inexperienced amateurs who are using CW without knowing how to operate as properly as they should.
Today, on EA8/TF-012, the behaviour of a handful of malfunctioning chasers on 10m CW who were either sending their callsigns blindly and who could not hear me, or who could not understand basic CW messaging procedure, because they cannot read Morse Code, ruined the early part of my 51 contact 10m CW/SSB activation today.
With meagre power and a makeshift antenna it proved impossible to control the melee that erupted within a couple of minutes of coming on the air on 28044 KHZ, so much so, that I went QRT on CW after 12 minutes and resorted to my second favourite mode of SSB. I returned later to CW on 28057 listening up 1. Thank You to the many chasers who were disciplined enough to operate split, by calling me on 28058 - it was my pleasure to get so many of you into the log that way…
Due to the behaviour of certain operators (the worst two disruptive offenders had Belgian callsigns), this evening after the Sangria had been drunk, I decided to closely scrutinise the excellent “Show who chased me” section of the SOTA database. There was a few minor logging errors in modes, no worries there, logs can be easily corrected by the two chasers concerned, however five chasers have logged a QSO with me which did not take place. These are:
EA8CCA (Not logged - informed via email)
ON4ZD (QRM)
ON7ZM (SEVERE QRM - informed via strongly worded email)
N4MJ (Not logged)
PY5XT (Not logged)
If you are one of the five please remove the contacts from your log and the SOTA Database.
SM4CJM and F4WBN were both worked after I was forced on to SSB, but were logged by the Chasers as CW contacts in error.
The activation of EA8/TF-012 was my final activation of 4 in Tenerife this week. I will be back on the 10m band joining the Chasers on Saturday!
After highlighting this, and with the 10m Challenge especially in mind, I hope other activators will check the “Show who chased me section” - it was quite revealing. If you don’t run a routine check and ask for corrections or deletions then it appears the integrity of the SOTA database is under threat - 5 out of 51 QSOs that did not take place is a 10% error rate, so that’s not good for the database and for SOTA.
73 and MNI DX to all,
Phil EA8/G4OBK/P
