EA spring meeting may 30 and 31 2026 Awards
To encourage all the operators who are going to be at the top those days to get the 4 necessary contacts, we put on the air a series of diplomas commemorating our activity:
AWARDS RULES:
There will be two awards:
General award:
For contacting any of the peaks that will be active on the weekend of the meeting. You will be able to download your diploma from the website once all the operators’ logs are uploaded:
https://radioanuncios.es/diplomas
Platinum Award:
To obtain the next diploma, it will be necessary to contact at least 15 (FIFTEEN) different operators on the summits and also obtain communication with at least 3 (THREE) different summits of all those that will be activated that weekend. Both conditions (15 operators + 3 peaks) are essential to achieve this. If you meet the requirements, you can request it by email. indicating the operators worked and the summits to the email: acabodehaceralaska@gmail.com with the callsign you used and your name also in the email. All the bands and modes within our reach on those days will be used: HF, VHF and UHF but only valid SSB, FM and CW for Platinum Award.
To add an operator to your list for the awards, you can repeat the contact on a summit reference if it is operated by different operators even on the same band.
Each operator using their personal call sign will count towards the required 15. The special call sign EG26SOTA counts as a single operator, regardless of who is in command at any given time.
We are waiting for you at the peaks on May 30 and 31!!!
Awards start at 30 may 07:00 Utc to 31 may
23:59 UTC.
Official summits for awards:
EA2/TE-003 Caimodorro
EA2/TE-004 Sierra Alta
EA2/TE-005 Muela de San Juan
EA2/TE-023 Alto de Tremedal
EA2/TE-024 Peñablanca
Official operators list will be update next days.
73s from all the Bronchales team 2026 operators.
Valid stations for awards:
Cesar EA4IS
Alberto EA3GNU
Juanjo EA3HIG
Carlos - EA5JYX
Roger EA3ISA
Mariano EA5JTS
Guillermo EA4BQG
Toni EA4BVW
Alejandro EA4DON
Elena EA4DOS
José EA7GV
Sam EA4AWF
Quique EA4GVU
Juan EA9ADD
Jorge EA4HFO
Agustín EA4NB
Javier EA2EXN
Mikel EA5IYL
Mijail LB8CG
José María EA4IGO
Nacho EA5HKG
