As these last months the activity of S2S between VK and EA2 has been increasing, and suspecting that we could be using other frequencies than bests, I’ve tried to find the optimum time and band schedules.
We, AFAIK, are making these contacts using 14 Mhz on the first light hours by long path, leaving upper frequencies even when the sun activity seems to allow good working conditions there.
So, I have made some calcs using VOACAP web pages (+10), and these are the results obtained. More or less they are valid for all VK,EA , and G zones:
Best hours (always UTC):
from 8 to 10 am, long path
Frequencies:
- Between 8z and 9z: 18Mhz.
- Between 9z and10z; 21 mhz
Best conditions: between 8UT and 9UT on 21Mhz. The probability of making contact, using 25 watts, CW, and 1/2 lambda dipole @10m, is around 69%. At the same hour, on 14 mhz, the percentage is only of 4%. mmm…
Obviously, times would be approximates, but could be a good guide to use in our attempts.
Tomorrow friday 3/10/2014, we will try -at least on our side- to use these data to see if they are reliable enough.
I hope all this could be useful for our activity on achieving better DX SOTA QSO’s.
73 de Mikel
Figure 1: input data and time table
Figure 2: the data obtained X axis = time(UTC), Y axis: frecuency (Mhz)
Solar activity data (short) http://www.hamqsl.com/solarbc.php
