When you have a summit that has two peaks that are only like 3 meters, (10 feet) difference in elevation, and about 500 feet apart, can we use either summit for the activation?
Joe
Joe
If you can prove that the lower peak is in AZ then yes. Normally it is just so much simpler to go to the position given in the database.
The horizontal distance between the peaks is irrelevant. What matters is that to get from the summit to your operating position you never have to drop more than 25m.
