Has anyone any experience in using the HF digital modes on a hilltop?
I can see a dis-advantage of having to carry more weight with a laptop/netbook as well as the radio gear. Could be an idea for the 1 pointers??
73 de mm6adr
73 de mm6adr
In reply to MM6ADR:
Yes.
Not worth the agro to be honest. Couldn’t see the screen in the sun and had to carry an extra kg or so. It was nice to get 4 PSK-31 contacts but I doubt I’ll do it again
http://www.flickr.com/photos/mm0fmf/2483108545/
In reply to MM6ADR:
Works even for 10 pointers though I do mostly cw and I do not know any active chasers on digi.
The wind can be a problem for the setup above, since the microphone picks it too.
73, Jaakko OH7BF/F5VGL
Thanks for the info Andy.
Did you find the 5W was sufficient to get the qso’s?
What interface have you got for the 817 or is it homebrew?
What band and antenna did you try it on?
ADRIAN
In reply to F5VGL:
I started PSK31 last month from F/NO-007; had on 10MHz a nice QSO with Feri,HA7UL who is also a digi SOTA activator.
Next friday (and maybe sunday), I hope to be again on air on PSK before CW.
(FT817 + Bux com interface and MMVARI soft on a 1.4kg netbook)
73 Alain F6ENO
In reply to F6ENO:
Hello all
I recently built a NuePSK modem. If I can find the trouble in it, I’ll try it for sure in my next activation.
JP VA2SG
In reply to MM6ADR:
More than enough. Far too many people run massive powers on PSK31 when it’s not needed. QRP is ever so effective for narrow bandwidth modes like PSK31.
Homebrew of course. It’s only a BC109, a resistor and two diodes with a cheap USB<>RS232 dongle.
60m and inverted V.
I wonder if anyone has tried the app thats available for the iphone on a sota activation, it would be a lot easier to carry than a laptop or netbook, dont know about interfacing though…
My brother LA1CNA Roar has activated LA/TM-049 with CW from computer and SSTV with small computer and FT817 and dipole antenna.
