I can’t seem to upload this week’s S2S on the 2200m band between VE6IXD and myself – see [S2S contacts using 2200m band (136 KHz)] , whether as a batch upload on a csv or as a one-of QSO loaded directly into the database. The pop-down list in the frequency field still includes VLF but when you try to submit you get an error message that this is not a valid frequency - see screenshot. I tried putting in 0.135 MHz in the frequency field on a csv upload file instead and that did not generate the same error message, but the upload software translated that as “microwave”. I hope this can be fixed as I’m really stoked that Ian was able to orchestrate a “near field” S2S on the 2200m band using traditional cave radio techniques but the latest QDX-M rig.
Looks like a bug when I tried it. You have 2 choices. Wait till it’s fixed then enter your log. Or enter it by changing the band (1.8MHz say) and put a comment in that it’s really 2200m. When the bug is fixed you can edit the QSO to reflect the true band.
This should be fixed now.
You bet, it works fine now. Thanks very much for super-quick and effective response!
