Hi all,
Since 10:24 UTC I can’t log any chaser QSO directly or not.
73, Éric
F5JKK
Hi all,
73, Éric
F5JKK
Nor I Eric
It’s fixed now.
Hi Eric,
I have the same problem here.
73 de Jan
Merci Andrew
Cheers Andrew
Firstly, sd3.sotadata.org.uk is not the latest, use www.sotadata.org.uk. Second, I can see your queries are being handled correctly.
Hello,
I have seen the same problem at 10:04 UTC by direct login.
Now it’s OK, I was able to log the qso’s
Thanks a lot
Laurent de F8CZI
Yes until you erase your pending entries on SD3 will not work, after a clean entry menu worked perfectly took me 2 hour to understand
Many thanks 73
