Data modes
One for all the operators on the data modes what program r you using for the data modes i am trying ham radio deluxe dm780 at the moment but having problems sorting out the macro’s can any one suggest a easier program so i can do some chasing on the data modes cheers for now Dave M3XIE
In reply to -M3XIE:
Dave, I use DM780. Are you using the macro manager? What sort of problems are you having?
Mike G6TUH
In reply to -M3XIE:
Hi Dave,
For PSK31 / PSK63 I use WinPSK which seems pretty simple to use. For RTTY I use MMTTY, which is also pretty simple to use. I don’t think I have ever chased SOTA using RTTY but I have chased using PSK31 & managed to work Darius MW0KCB/P on GW/NW-0012 Cadair Berwyn a short while ago. I used a very short exchange rather than the long & detailed exchanges usually used in PSK QSO’s.
Thanks for the call on Saturday when I was on Longridge Fell.
Mark G0VOF
In reply to G6TUH:
All sorts mike from setting the macros up to working out to working any one i.e i can make the cq call but can not work out how to reply to the call do i ilite the other call sign etc.
In reply to -M3XIE:
I use fldigi, it’s available for both Windows and Linux, it does nearly all the data modes you are likely to want and it’s simple to use. More importantly, it’s free and it’s well maintained and updated.
http://www.w1hkj.com/Fldigi.html
Colin G8TMV
In reply to -M3XIE:
Dave, when you see the incoming signal callsign in the upper pane, click on the callsign - the call will then be placed in the log holder to the left. Thereafter that call will be automatically be placed in the macros. So macro ‘him de me’ would turn into eg. G6TUH de M3XIE.
For SOTA chasing I have just used the above macro and typed a quick response and report to the other station. As has been already written the long winded macros are not wanted by the SOTA activators.
Later on today I will write something up with screen shots and email you. DM780 is very good and the superbrowser is great. You should be good to go if you follow what I send you - I hope 8).
Mike G6TUH
PS: I am using the v5, before it went commercial.
In reply to G6TUH:
look forward to that mike looking forward to receiving that and many thanks for the help 73 Dave M3XIE
