I been trying to figure out a easy way to convert the .csv from SOTA to an .ADI file with not much success the closest thing I have found that will work for eQSL is Conversion CSV->ADIF V1.0 software, but I think eQSL does not understand the date format. Does anyone have any suggestions?
Thanks AC4M
In reply to AC4M:
I’m sure you’ll find something here that will work…
http://www.on6zq.be/w/index.php/Trails/SOTA
Andy that webpage does not help either almost all the data are in the wrong order. I am open for some more suggestions.
In reply to AC4M:
Thanks for pointing out this since the header names in the CSV file seem to have changed a little. I had to update the hash %cconv in my ‘adifmerg’. The details are in the repository GitHub - oh7bf/adifmerg: Small conversion and check utility for ADIF files. .
73, Jaakko OH7BF/F5VGL
In reply to AC4M:
May be it can help:
http://www.sota-france.fr/pages/programmes/CSV2ADI_V2.zip
An old program; it is in french, but you only have to load your CSV file, then save the ADIF file
73 Alain F6ENO
In reply to F6ENO: That helped a lot with your software now it is reporting the wrong band
WX4ET AC4M/P 20130415 1542 W4T/SU-062 4m FM
it should be 2m and the csv reports 144mhz
