3.5 Guidelines for the definition of a Summit
Each Association is required to determine a strategy for defining a list of Summits that is consistent with the nature of the general terrain in that Association. The definition must take account of the following guiding principles
The Association must have sufficient topology to enable meaningful Summits to be defined. The SOTA Management Team recommends a minimum prominence for summits of 150m. The minimum association prominence that can be accepted in the Programme is 100m. In the event that this rule cannot be met, the Entity or Subdivision will, unfortunately, be unable to participate in SOTA. Prospective associations wishing to use a prominence of less than 150m will need to be able to offer sound justification for their preferred value, and be able to demonstrate how the use of a lower prominence value will significantly add to the viability of a prospective association.
Summits should be distinct peaks. This means that there must be a vertical separation of at least the association’s prominence value, between Summits and their associated cols (also known as saddles). Peaks separated by a shallow col should be considered as a single Summit. This principle ensures that there is a distinct climb associated with every Summit.
The Programme is intended to be inclusive in nature and therefore Summits should not be limited to the highest points in an Association. To encourage participation by as many people as possible, any summit that meets the requirements of principle (1) above should be eligible for inclusion in the programme. An Association Reference Manual that does not include a suitably wide range of Summits, when such peaks exist within its boundaries, is liable to be rejected by the Management Team.
Summits that are accessible by road can still be included in the programme, although operation from vehicles is not permitted.
It is recognised that operation from the exact top of the Summit may be difficult or even impossible. It is also important that SOTA operations do not disturb the enjoyment of the mountains by others. Accordingly, each Association shall define the Vertical Distance from the precise summit, within which a Summit operation will be considered valid.
In the UK we use the Marilyn summit list which is verified independently of SOTA.
Also, just because a hill has a trig point that does not automatically make it a valid SOTA summit.
No problem. Very few people initially understand what prominence mean in this context thus this question comes up frequently! But your hill has a trig point so it will count for the new WAB award.
Sir
That is the information one is after
Big thank u Mike
And yes the rules some what hard to understand in places but what said gent G3CWI explained it perfectly and a grasp has been reached and understood why its not on the Sota site and the trig site is giving me ideas in relation to the WAB award
To what one meant the trig point referred cox hill not being on the Sota list G/DC
yes the rules are there and better explained to me now and understand that section
Maybe you should have said that then. Or maybe ask Santa to bring you a bag of commas and full-stops for Christmas next year. Or see if you can find some in the sales.
I think the best thing to do is to visit the location and see what you find. I recall you have need to care for your partner so you may not have time for such research but if you do it will be worthwhile.
I was very surprised that Kent has so many trig points - 800+.
Cheers for that mike
Just drag her along she likes the country side, not so much climbing up and down the hills thou.
Have found on the trig site local here, but three are built on and one is on top of a MOD site just over the bridge. 800 in Kent wow that,s a lot, but again thanks for the link well useful info for have to learn now when find a Sota in UK after 1st Jan for now can find its trig number as well its WAB square too. Surprising how many WAB squares one has gained doing Sota alone.
Yes 2015 is going to be interesting for sure.
PS Kitt hill (G/DC003) has two trig Numbers one for the pyramid concrete square and the tower that’s near by, so will that be a bonus when one is up there activating the G/DC-003 plus its WAB SX37.
