Consistent Callsigns
Can operators be consistent with their use of callsigns?
G9ABC/P is not the same callsign as G9ABC.
If you use one callsign on air but upload against a different one then the “Who chased me” feature won’t show the QSO.
If an activator is using G9ABC/P, don’t log the contact as G9ABC. Although SOTA points are not affected, the QSO won’t match for a POTA P2P or in LoTW. And “Who chased me” won’t work.
I’ve heard activators spot as one call and use a different call on air. Even worse, I’ve heard them switch between the different calls. How am I supposed to know what callsign to log the contact against?
Not quite so.
Who chased me shows all chaser with your logged call sign in the top section.
In the lower section, Who chased me shows all chasers and the activator(s) callsigns, as logged by the chaser, on that UTC day, for that summit.
Well it should be.
In those jurisdictions where the rules say the suffix is optional that’s an argument that can be made, but there are jurisdictions where suffixes are mandatory in certain circumstances, and there are QSL systems which treat calls with and without suffixes as different.
Hi Richard, this is not the POTA forum, however the method in POTA when you want both forms of the callsign to match is to enter the call sign with /P as the club callsign and the one without the /P as the operator callsign, in that way all combinations work for P2P contacts. In SOTA, as the activator you can define multiple callsigns to your account so that cross matching works so, in this case M9ABC would also list M9ABC/P as a an extra call sign in their SOTA profile.
I can’t comment on LoTW as I don’t use it.
73 Ed DD5LP
Indeed, I have heard this. I’ve even worked someone activating in another scheme, signing /P and then an eQSL has arrived without the suffix. Looking at their submitted log data revealed sometimes they submit logs with the prefix, sometimes without. Bizarre and annoying for the chasers, but I suppose I shouldn’t be surprised when we live in a time where discipline has disappeared.
Personally I wouldn’t think of operate portable without signing /P. It does add to the interest for others and when I’m not busy working a string of contacts, I’m often giving details of my set up, what it is like to be sitting in the middle of nowhere or even getting down the basics of what makes me do it. :grinning_face:
