does anybody have an idea, how 20m-condx will probably be on Lofoten (LA/NL) for doing some SOTA-QSOs? Is it very difficult? I will be there in early June and have no experience how condx are at such high latitudes, compared to Germany… I have 20m, CW, 10 Watts, only.
I have operated from similar Latitude (northern TF) and condx are certainly tougher than operating from central Europe.
That said with 10w of CW into a dipole I had no problem completing an activation and made quite a few non-SOTA “campsite portable” QSOs .
Good luck!
73 Gareth G0MFR
I used to live in Bodö and on Andöya in the late 50’s;
During June you will have daylight more or less 24 hours a day up in the Lofoten Islands. HF propagation will be OK on 20-17-15 mtrs depending on the state of the SUN e.g. sunspots or lack of !
Don’t forget that even if you cannot see it during the continues daylight conditions; there will be periods of Aurora conditions which more often than not will wipe out out HF propagation.
During my trip to the North Cape in 2014 I made a lot of QSO’s on 20 mtrs., but 40/80 was virtually dead.
Enjoy your trip !
73 Ken
We did 2 activations on the Lofoten in July 2018 and never had problems getting the necessary contacts. Peter OE5AUL and me worked on different bands but as he said in a previous answer - take a vertical antenna with you!
Be prepared that the band might open to eu not much earlier than local noon. It might sound much quieter than in central eu but with some ‘good’ signals from the south. In the rare case of a midsummer aurora you won’t hear anything if you’re in the auroral oval.
I was going to activate a summit or two in the Arctic Circle last year from Finland. I put it off as I didn’t want to make the journey and spend lots of money only to find that I could only work a few stations due to the bottom of the solar cycle and my location so far North. I decided I’d wait till the solar cycle has got going and then try.
But seeing Slyvia’s photo… well I could go there and I wouldn’t care if I didn’t make a single QSO if I could see that view on such a day
Hi Axel,
If you activate at around noon and there’s no aurora black out, you should be able to get chasers from Europe and possibly some of the early Northamerican chasers too.
You asked about 20m, but just in case you want to consider other bands, let me tell you that 17m and even 15m will also work fine into EA and possibly other Southern EU areas.
Good luck.
Andy, that’s true, no need of SOTA to go there. Scenery alone is enough. But if possible, I’ll give it a try.
As to other bands than 20m, that’s the only rig I have. I’m waiting for the QSX-transceiver from qrplabs to be released. And regarding a vertical antenna, I consider to build one, at present I use an endfed, mounted as inverted-L.
