I was just west of the summit of ZL3/WL-318, mid afternoon Monday. Known locally as Ridgeline this summit is the southern peak on the sometimes knife-edge ridgeline between the Lake Greaney basin and the deep depths of the Waiatoto valley, a 1500m stone’s throw to the east.
Weather was light whispy clag, the sun almost visible through the haze, temperatures in the mid 30’s on the coastal plain 1500m below, and still hot and humid even at this altitude. I stopped for no more than 2 minutes, stowing tools in my pack and taking a much needed swig of water.
When I looked up the bright hazy day had turned black. Goosebumps were already prickling on my sweat-soaked skin as the temperature plummited. I grabbed my pack and proceeded to get outa there! No easy task on a knife-edge ridgeline where the only safe options were a cautious scramble along the crest.
5 minutes later saw me 250m from the summit and maybe 80m below it, focussed on the tricky descent.When three things happenned in rapid succession.
- Someone punched me. Simultaneously, over the full length of my body.
 I had time to think ‘what the …’
- I was aware of an intense flash of light
- Maybe a second later the deafening clap of thunder followed.
The lightning appeared to have hit the summit, maybe 300m away.
I spent the next 30 minutes cowering under a seriously inadequate outcrop of rock until the heavens ceased hurling 20mm hailstones at me, and mentally filling in the ‘near miss’ report form.
Now, I assume the sensation of being punched was my body forming the secondary winding to the transformer the lightning path had just created the primary of. But does that stand up mathematically, over that distance?
What puzzles me is the sequence of perceived events. In my perception, the punch came first. I had time to question it’s cause before I sensed the flash. This could just be delays in perception, but if so it seems back to front: it’s more usual to see injuries happen and have time to anticipate the pain before it arrives.
Or is there an electrical / physics explanation? A delay between the current flow and the ionisation of gasses that causes the flash.
Answers, musings and digressions appreciated.
