Indeed… Barry was happy to take my claim for MG on 2m/70cm only on Unique summits and that was back in 2010.
Opening the Activator Honour Roll and filtering by band only shows which summits you’ve made contacts on the selected band… not whether you have actually qualified the summit on that band. For that you need to go through your records manually… a bit of a drag, though it was relatively easy for me as I started on 2m and HF only came along a bit later and then alongside 2m operation.
You can use a spreadsheet to speed this up but it would still need a bit of manual checking (or perhaps a macro).
On the Activator Log page select All Entries for the year and click on Show Analysis. Cut and paste the page into a spreadsheet. In a new column check if the number of 2m (or whatever) QSOs is >= 4 and if so it’s equal to the points+bonus points. Then sum the column. This may undercount if you activate a summit more than once in a year and the first time you qualified it on HF but didn’t get 4 2m QSOs and then revisit with 4 or more 2m QSOs.
There may be a better way but I did this in 5 minutes.
Well many thanks for that. If I do make Double Goat before I hang my boots up it will be Unique summits only and no consideration given to bands… 2m didn’t work from quite a few of the summits I’ve been on since 2010. Not surprising really given where they are.
