My licence was up for renewal this year and i used the opportunity to get a new, shorter callsign.
Would be one of the moderators be so kind and change my call on this reflector?
Previous: S56KVJ
Current: S52CA
Thanks!
That was fast, thanks!
Hi Valdemar,
congrats and good luck with your new “light-wighted” call !
S56KVJ was 76, now S52CA is 60 !
RadioQTH - CW Call Weight
Vy73 and cu on the air
Fritz HB9CSA, DL4FDM
Mine is 106
HB9/MM0FMF/P = 164
Vy73 de Fritz
…except that the second “M” gets dropped in an overseas call, so that’d reduce it by 10. Still quite a heavyweight, though. Mine’s 62, and the heaviest version I’ve used so far is 5Z4/M0LEP/P which is 148.
Light weight isn’t all it’s cracked up to be. I might as well have changed my callsign to “WU7?”
Ur callsign is plenty light enough for me Josh. Pretty easy to pick out of a SOTA pileup. Yours is 4 points lower than mine at 52. My original FCC call (WA1UGZ) is a 76 and it was a nightmare and took forever to send in a pileup. AND Congrats to S52CA.
73’s
Tim - K5DEZ
