Carrying an IC-705
In the two years that EA4DOS Elena and I have been in the Sota world, reading this Reflector has been a continuous source of knowledge, initiatives and ideas to be developed for a better enjoyment of the activity.
For our part, we have been sharing the passion for the mountain for 51 years, now enhanced by radio activity, in which we have designed multiple elements or accessories that allow us to face the hostile defenses that the mountain sometimes puts on us when we approach it. .
When we consider transporting the equipment, we think of a case from which it does not have to be removed, once we arrive at the place of activation, and it is put into operation with its various connections, batteries, cw key, micro etc.
We present you the images of the case that we have designed and built according to the elements that we use, and based on our experience.
Box with rigid and padded walls, with Velcro closure.
Portfolio for contact list, which at the same time protects the content.
Padded lid like the rest of the inside of the box.
Distribution of the transported.
Content. The yellow flanges of the frequency selector are to facilitate its rotation.
The cw key box is now used to give more amplitude and resonance to the speaker output, when headphones are not used.
When the space at the top is very limited, as in Ref EA4 / MD-055 constituted by a narrow rock, we use the Elecraft AX-1 telescopic antenna.
For its fixation we have provided an accessory that stabilizes it and keeps it attached to the case.
Clamp and snap closure.
Sometimes the strong wind, or an anticipated rain, advises us to use the bothy bag, in which we have made a small hole that allows us to use the antenna arrangement previously presented. Now in Ref EA4 / MD-045.
If that rain surprises us when entering or returning from the mountain, we have created the waterproof cover with a “chimney”, which protects the sensitive material contained within.
Greetings to all, I hope to hear us on the mountain.
EA4DON Alex
This looks just great!
If not too heavy, I’m pretty sure that you could sell something like that.
73 Stephan
Hi Matt,
I totally agree :wink:
73, Jarek
Some great ideas there; love the modifications.
73 Matt
One more for SW-3B :wink:
73, Jarek
Home made enclosures above look very good. I have a minor concern though.
Some of those materials are very good insulators, and the design of the enclosures do not allow air to circulate, so heat generated in the radio will simply build up. In a cool climate that won’t matter, but in VK summer it would most likely overheat the radio. Allowing for air circulation is essential in higher ambient temperatures.
For this reason I use an enclosure to transport and protect the radio gear, but extract the radio from the enclosure for use.
Andrew VK1DA/VK2UH
Hi andrew,
You are right, even in the “sunny” EA summer, padding materials in the bag could lead to some heat build up. In my little experience last year (will see in 2021 summer), this produced a slight rise in temperature indicated in the IC-705 meter screen, but as I use to have the IC-705 not totally inside the protective bag, that was, at least in my case, not a big issue.
73 Moises EA4MZ
Hello,
My kx2 travels in a medicine cabinet made by TupperWare. It is very light and quite watertight.
Tomorrow EA7/GR-059 :grinning:
Having been a photographer for the last 30 odd years, I quickly gave up on Peli cases. In most cases they weigh more than the equipment you put inside them. They are fine for protecting delicate equipment in cars, but not great for climbing up mountains with! I am currently looking for a lightweight solution for a G90.
After having finished the red wine bottles contained in this wooden box, I customized it years ago for a perfect fit of my FT-817ND and my MFJ-941B antenna tunner inside, preconnected with each other, the external antenna connection, cw paddle cable, microphone cable and a pair of earbuds.
The hand microphone and the paddle go in the side compartment of the rucksack.
Now with the wooden lid on:
Everything inside an isothermal plastic bag for some protection in case of rain, although I’m not one of those activators going out under heavy rain conditions and wx in my area doesn’t change too fast.
I know this is not for IC-705, but you could well customize yourself something for your rig the same way I did for my rig years ago.
I’m very happy with what I did as it lets me activate without needing to take anything out of my rucksack and only needing to connect the external battery lead and the external antenna.
Guru
Sounds like you need to order a new box Guru!
Over the last 50+ years I have found that both boxer shorts and Y-fronts are wonderful methods of safely packaging and transporting very sensitive and easily damaged “gentleman’s artefacts”. I wonder if anyone has considered wrapping their sensitive and easily damaged radio items in boxer shorts or Y-fronts?
While you’re at it you can get them silk screen printed with the SOTA logo and fly them from the pole! :rofl:
BOTA? YFOTA?
YFITA!
Given the last year I had, since it’s said that as wines improve with years, we can also say years equally improve with wines, I’m determined to prove it and I can definitely say it’s true after having been emptying boxes like the one in the following picture at quite a regular pace lately.
However, these boxes are not wooden but card board ones:
My current wooden box is still in perfect conditions and I forecast many more years of SOTA activating with it.
Guru
This is a travel shoe case I’ve been using for my FT-857, mic, batteries and logbook. The IC-705 is the black item with the white foam.
I cut a front protector from some white foam I found in the scrap box.
On the outer side, spaces were cut for a 4 mm peg (Ikea), a 1/4" screw (old tripod) and a BNC/UHF adaptor.
The 4mm peg is redundant now. I used it to lift the front before I found the 1/4" screw.
Ahoi
Pom
Are jewels crystals?
I have used a leopard print DD cup womans undergarment which offered great protection to my FT-817.
I have asked for some assistance for the Icom 705 but with COVID lockdown I am looking to do this curbside or via Zoom
John VE3IPS
Hi Pom,
Good idea for the front protector, in my bag I use a plyed soft polystyrene sheet, but is better to have a thick rigid piece formed with the IC-705 holes. Thank you.
73 Moises EA4MZ
