Cannot upload, edit or delete gpx-files
I just wanted to upload the tracks from today’s activations but it was not possible … this message stay’s here “forever” (waited several minutes, should take only a few seconds):
grafik
When i try to edit or delete a track it is not possible because the “security code” is not showing:
grafik
grafik
Is a “security code” still needed? Now with SSO i think it’s obsolete …
And can you please add VK3ARR to the CONTACT page for SOTAMAPPING:
grafik
Thank you
73 Martin, OE5REO
The contact page is under update review as I type. You can contact Andrew via the contact page on the SOTA maps site.
c1
Secondly, you can attract any user’s attention to a thread by typing their callsign with an ‘@’ at the start.
@VK3ARR will prompt Andrew to check this thread.
I tried to contact @VK3ARR today but submitting the report was not possible:
But I’m sure he will notice this thread here soon!
73 Martin, OE5REO
Yep, fixed the contact form piece. Will take a look at the other things soon.
Thank you for fixing these problems … today I managed to upload, delete and edit gpx-files again!
73 Martin, OE5REO
Today I have the same problem as Martin, I can’t upload tracks @VK3ARR
I get a popup that says “No points” and the “Checking uploaded file” runs forever …
My track is ok in GPX Editor.
I use Chrome on Win7.
I hope it can be solved soon …
Tnx es 73
Luc ON7DQ
I’ll see what I can do.
This should be fixed, but there’s possibly some other error underlying that may need me to break it again (thought I’ll try very hard not to! :slight_smile: )
Tested and it works ok, thanks Andrew !
Luc ON7DQ
Hello all,
tried to upload a new track to SMP but after entering all the data and clicking the “SAVE” button nothing happens … tried it several times the last three days with different browsers (firefox / chrome) but it is still not working! At least the “CANCEL” button works … :slight_smile:
Bug report already sent via the SMP contact page! @VK3ARR
73 Martin, OE5REO
Hello Martin,
I have absolutely the same problem.
Andrew said he will have a look soon.
I guess my prob is because few monthes ago, we had to change my ID that contained a bad caracter.
Wait and see…
73 from Gerald
I suspect that I have broken something in the authentication or upload for SMP. Currently on holiday, so no ETA :slight_smile:
Hello Andrew,
It works now! when i upload or edit a track, i get a nice “Track save ok”.
Thanks for the job.
73 Gerald
The upload worked for me as well!
Thanks for fixing that …
73 Martin, OE5REO
No problem, easy fix in the end.
Hi Andrew,
I’m trying to upload a GPX Track but getting the “Checking Uploaded File” box staying there forever again.
Geoff ZL3GA
This should be fixed.
And it’s back! Thanks Andrew.
From a couple of days I´m trying to upload a track but the message ¨Checking uploaded file¨ is rounding… and rounding.
Maybe the same issue?
73, JP3PPL
Should be fixed now. Was working until about midday yesterday, then went away.
