With a decent forecast at last (its only mid-June…) I went for Cairn William yesterday June 19th, a nice little 1 pointer 40m drive from home. I first activated this just before Covid lockdown. On my first visit I took the Walkhighlands route from the mountain-biking car park, but that is quite a long walk in, so this time I went for a shorter route, starting to the South. Fraser, MM0EFI, last went up from the North but as his parking spot looked a wee bit limited to me and there wasn’t too much difference in distance from my spot, I went with mine.
Route up © Ordnance Survey 2024
The first section is a bike trail (not used very much) that leads uphill through the trees and joins a wide logging track. Follow that to the right until a mountain-bike trail post appears, marking the Granite Top Trail (Red)
This wide trail leads uphill to the point where a number of bike trails meet. The Cairn William ascent is marked with a NoEntry post. Care needed in walking up this, as it is possible to meet a bike descending at high speed and there is often not much room to get out of the way. However, this was mid-week and there were only a few cars in the main car park which I had passed en route to my start point. Nevertheless, I stopped regularly to listen and scan the hillside for bikers, but I only saw one at the summit all day and 4 pushing their bikes up the wide trail as I went down at the end of the afternoon.
Activation
Equipment: KX3, Quansheng UV-K5, Sotabeams linked dipole 40/20, Spiderbeam 7m mast, homebrew 6m alu mast, homebrew 2el yagi for 6, 10 and 12m.
I set up close to the trig point and was qrv at 1245 utc
40m: Good inter-G signals heard and band quiet but very few chasers. Just 6 itl including Chris, MM7RVC from the Deeside group and only one outside the UK - F5PYI
20m: band very quiet. Just 7 itl, 6 regulars including MM7RVC again and Mike 2M0WNA also from the Deeside group, finishing with SQ6EO/P
10m: I could hear some French stations, so I knew the band was open to the South and F4WBN was quickly itl 59 both ways, followed by MM7RVC for his 3rd band chase, a French mobile F6GNP/M and then an unexpected S2S with 2M0TFF - he called me after getting a QSP from Steve MM0XPZ who could hear me but I couldn’t hear him - Steve had earlier worked me on 40m. last itl on 10m was Mike 2M0WNA again.
6m: I reconfigured the yagi for 6m, which took about 10 minutes but this was the first time I had done it on a hill. I2OLV was calling CQ, so I worked him and then spotted. The reliable locals called in - MM7RVC and 2M0WNA, but nobody else. The band was only just about open to the South and I worked CT7BIZ as last itl on 6
12m: reconfigured the yagi for 12, which took extra time as I put the reflector add-ons on the driven element and vice versa - KX3 ATU not amused. I need to change the colour coding on the tent poles
The band was very quiet but I could hear a few EU stations, but the only caller was MM7RVC, so I suggested to Chris that we needed to try 2m to get a 6 band chase
2m: while waiting for Chris to put his antenna up, I worked Fraser MM0EFI, to give him a Complete and then Chris came on for a 59 both ways. Great stuff.
Just the 25 itl for the day, but it was nice to be back on the hills in decent weather. 73 all.
Summit views
Looking NE, with Ben Rinnes GM/ES-021 and Tap O’Noth GM/ES-054 L-R
Looking North at Bennachie-Oxencraig GM/ES-061
Looking SW at Morven GM/ES-018
Looking down on village of Monymusk
