W4C
W4C/CM-164 is being replaced with new summit W4C/CM-194. This change will proceed on 1st July.
There were various other tweaks, including a name change for W4C/WM-021 from “Tusquitee Bald” to “Signal Bald”. This actually reflects a position change, with a swap from the former high point to its neighbour. In this case the Tusquitee Bald position is anyway still in the revised activation zone and is still just as valid a position to activate from as the new HP.
W4V
W4V has had a refresh from Lists of John and also a reduction in required topographic prominence from 500 feet to 492 feet (150 m). There have been 23 retirements, several of which have been replaced by near neighbours found to be higher, alongside some other unique summits. There is a net overall increase by 7 summits.
W8V
W8V has likewise had a refresh.
In this case only one summit has been retired - W8V/NR-060 - which looks to have had its high point mined away. There are 11 new refs.
DM/RP-494
Renamed to Sindelsberg
TK
New summits:
- TK/TK-167 (Capu d’Occi)
- TK/TK-168 (Capu di l’Amandoli)
- TK/TK-169 (Torre Truccia)
Retired summit:
- TK/TK-107
(A couple of other updates being worked on)
