I’ve logged in to the SOTA Database to log a chaser entry from yesterday. I filled in all of the details, pressed submit and got an error saying “not logged in”.
I checked my previous logs and nothing was showing up - no entries visible.
I logged out and back in and it was still the same.
I tried to add a chase as you and it failed with the same error. Wouldn’t let me add a chase as me and isn’t showing my logs. I can look up summit info however.
It will have to wait till one of us can look further, I’m at work and cannot access the servers. Not sure about Andrew @VK3ARR and Josh is asleep.
OK, should be fixed now. Earlier today, I added lat/long to the token that gets sent back by SSO. Now, for reasons I can’t ascertain, the SSO server decided that it should switch from sending a claim with a field called UserID to a claim called userid (lowercase).
There’s no obvious reason such a thing would occur and there’s nothing I’ve done to edit any of those fields, but I managed to work out where it was coming from and remove that - but that selection has been in place for years, so unsure why it would suddenly change (other than I added unrelated claims to the token earlier today). Anyway, logging in/out will immediately fix it, or you can wait for 5 minutes for the token to expire and a refresh of it with SSO to occur.
