Another South Korea SOTA post
I just received my South Korea Radio Station License (HL1/WX7OR). I plan on doing HL/GG-015 and HL/SL-012 on October 23rd. I would like to start at the Samgaksan Doseonsa Temple. Is there as bus that goes there from Seoul or should I go Bukhansan Ui and take a taxi?
I might also attempt HL/SL-009 or HL/SL-002 on the afternoon of the 22nd. Any advice to help me decide between the two would be appreciated.
I will have my IC-705. I plan on trying to find a out of the way place on the summits and use a EFRW antenna. I will also have a 2m whip.
Thanks, Jeff WX7OR
HL/SL-009 is easy to activate. Just take the bus or the cable car up to the summit, sit down under the gazebo at the summit and fire away. I just did that last evening. The 2 metre calling frequency is 145.500, but I announced myself on 145.020. As to setting up an EFHW, I don’t see an easy way to do this, as the place is crowded most of the time.
There is no space to put up a wire on Namsan, but I had no trouble on 2m when I visited.
Thanks. What day of week did you activate it? I will be there on a Friday and heard that there are not many people on the air on a weekday.
Hi Jeff,
First of all, welcome to Seoul!
The fastest way to hike up to GG-015 is to reach Doseonsa Temple by taxi from any nearby metro stations. From GG-015 to SL-012 is a pretty easy hike on the ridgeline.
All the summits you listed are usually packed with people or very narrow so installing any HF antenna is quite challenging. But I see you have EFRW, if you can lay them out in any way JA hunters with good antennas can chase you. (20-30m in the daytime and 40m as sunset approaches)
Also SL-012 has some space to properly hoist up shorter HF antennas which I have tried out before with a 11m-long one in the winter when there were very few people.
I think 2m is the way to go without drawing too much attention from bystanders, but you don’t have to leave out options for HF.
Btw, 2m/70cm calling frequencies are 145.000 and 433.000. If time allows, I will chase you in between work hours on 2m/70cm.
About SL-009 and SL-002 - both have radio towers at the top, so noise and desensitization is a bit of an issue. And both are usually crowded which limits the HF activation. If you prefer 2m/70cm SL-009 would be a great choice for a quick activation. But if you want to go out for a proper HF activation I recommend SL-004 which has an awesome view of the city and enough space for antenna. (You can find some photos on sotlas)
Feel free to reach out to me if you have more questions!
Thanks and warm welcome
Ji DS1TUW
Ji,
Thank you for the advice. This is my first time here. I have been in Gangnam the last two days and the mountains around the city look impressive. I can’t wait to get to them later in the week.
Jeff HL1/WX7OR
A very big thank you for Ji DS1TUW. His advice helped and he chased me on all 3 peaks. The most challenging for an HF antenna was HL/GG-015. It is not easy to see, but I tossed my EHRW over the boulder that resembles a face and tossed the counterpoise down the hill.
Jeff HL1/WX7OR
