Hi all!
Between 18-21 June 2025, I intend to activate summit DM/BW-861, Fremersberg. The only transceiver I could have is Yaesu FT-60 and RH-770 vertical antenna. I would appreciate it, if someone can inform me about the frequencies
that I should use at the area for german or/and french radio amateurs. I’ll put an alert as soon as I have these.
Co- activation is welcome!
Thank you in advance for any help!
73, Christos.
Hi Christos,
here you can find the frequencies the local communities are QRV:
The Fremersberg belongs to A03 but its also worth looking at the communities A04, A07, A24, A26, A40 and A50.
You can also try to get contact over a local repeater (https://repeatermap.de/) and then try to do QSY for direct QSO.
Anyway, the Fremersberg is not a “classic” VHF-UHF-summit as (especially to the south) the surrounding hills are much higher.
73!
Peter DL3NAA
Hi Peter!
Thank you for information! I see that Fremersberg is not the best for 2 m, but is what I can try in this occasion. I hope to gather 4 qso at least!
73, Christos.
Hi Christos,
the 19th of June is a holiday, at least in southern DL. If you want to we could activate the Fremersberg together. I have only a little /p-rig (QMX) but at least CW is possible and your chances improve.
I have been on Fremersberg three times before (BTW. at 17th of Feb 25 we had QSO while I was on Fremersberg LOL).
73!
Peter DL3NAA
Hi Peter!
Thank you for the proposal. We’ll be with my wife for a visit to our son, and I hope to have the chance on that day. But we can see it a little later, close to that date. My email is seen on qrz page.
Bis dann!
73, Christos.
