Summary of Activation :
- SOTA Summit: GM/SS-046 : Cnoc Coinnich : 764m : 4 pts
- Activation Date: Wed 16-Jul-2025
- Callsign used: GM7STP/P
- ALERT as : 13:00 UTC on 145-fm
- SPOT : QRV on 145.550MHz at 13:27 UTC
- Equipment : for 145-fm :
- Icom ID-52 handheld / 5W (used with rubber duck & Slim-G)
- Spectrum Comms Slim-G 2m / Sotabeams Carbon 6 mast.
- Successful QSOs :
- On 145-fm : 145.550 MHz : QSOs = 4.
Operation on 145-fm :
I set up by a rock about 60m from the summit cairn initially with the ID-52 and Slim-G. The same set up / connections as tried on Conic Hill GM/SS-251. This time I checked all was working by calling in to some local repeaters; e.g. GB3AY Dalry and GB3CS Motherwell. All OK, so Slim-G set up working. Back to simplex on 145.550 for CQ SOTA. Operating with OPEN squelch, I called CQ SOTA for a while without any contacts.
After about 20mins I then tried the handheld ID-52 with rubber duck and counterpoise instead of my Slim-G. Success ! …
My 1st contact was with Dan GM6CMQ over in Dunfermline; on 145.500 and QSY back to 145.550. Then as a test, I switched back to my Slim-G and Dan confirmed that my Slim-G set up was indeed working well with a very strong signal. Thanks to Dan, much appreciated.
I then continued with the Slim-G on 145.550 and after about 10mins made my 2nd contact with Alan MM6IQP/M who was down by Ayr beach. I felt I was on a roll ! … but then my 3rd contact wasn’t until about 40mins later. This was Alan GM3MWX down by Largs, Ayrshire.
One more contact needed for the activation … and then within 10 mins I was called by John MM7JFA, based west of Kilmarnock. Yippee ! my 4th contact and a successful activation of Cnoc Coinnich !
As time was getting on, I packed up and headed down back to the car.
Overall a successful activation. Very enjoyable QSOs.
Background stuff : Route & Photos :
Route Start : Forestry Commission Car Park at Coilessan Glen.
Route Finish : Summit : Refer to SotaMaps GM/SS-046 at 764m.
Distance to Summit : 4.9 km over elevation of 764 - 113 = 651m
Wx : A very sunny start, dry all day, with welcomed cloud appearing through the afternoon.
Route: Starting from the forestry commission car park at Coilessan Glen, the route follows part of The Loch Lomond and Cowal Way up to the ‘Cairn’ shown on the map. Then simply turn left and head up to the ridge. Then continue up the grassy slope and on up to the rocky summit.
OSMaps-GM7STP-GM-SS-046-01.jpg : Cnoc Coinnich at 764m “Contains OS data © Crown copyright and database rights 2025”
Photos :
Above: Photo-001 : Car Park at Coilessan Glen / Gate, bridge and start of track.
Above : Photo-002 : Bridge over river further up the track.
Above : Photo-003 : View up the path off the track with Cnoc Coinnich top left.
Above : Photo-004 : View back down the track. It’s steeper than it looks !
Above : Photo-005 : Cnoc Coinnich : Summit view.
Above : Photo-006 : GM7STP/P Cnoc Coinnich set up !
A great day out successfully activating Cnoc Coinnich !
Thanks for all the QSOs.
73 Peter GM7STP
