Activation from west coastal area in JAPAN
I will activate the followings
On 16 Oct, Mt Gassan JA/YM-002.
On 17 and 18, Mt Koshibayama JA/NI-190, very rare point of activation. This is also IOTA AS-206P.
Plan to activate with 14MHz to 430MHz including FT8.
See alert info in SOTAwatch3.
See you all on air.
Toru K JH0CJH
Done Activation from Mt. Gassan JA/YM-002. Thank you for call.
Far end is the summit Mt. Gassan
Last 100m hill climb
From summit
Fine day and no wind!
FT8 rigs
Toru K JH0CJH
A good walk. Thanks for the pics. What rig is that?
R
IC705
Thanks. I should have expanded the picture and read the model number. Nice rig and good to see it in FT8 mode.
Ron
Toru
It was good to work you from the Central CA Coast both on CW and FT8.
Thanks
Kent
N6WT
For FT8, I used IC705 with raspberry pi3b, which is upper side of photo, iPad mini in left is just display.
Toru K JH0CJH
Done activation from Mt. Koshibayama JA/NI-190. Many QSO with NA, VK & ZL stations.
Approaching Awashima isl
Mt Koshiba
Light house on Summit
Snap dipole antenna
Light house with antenna
Activation team
Port of Awashima isl and main land of Japan. Mt Gassa direction.
