Noticed these spots today … it seems to be showing the “/” as “%2F”. Not sure who is currently operating RBNHOLE, that’s why I’m posting this here.
73 Martin, OE5REO
73 Martin, OE5REO
Oh, it’s all me. This’ll be to do with the fix to work with the new API and HTML entities. I’ll take a look to see if it’s what I’m sending or what Jon’s API is accepting (the former being much more likely).
Seen another thing that might need some changes:
73 Martin, OE5REO
I thought it was just my bad sending!
Andrew,
You probably know this - the RBN Hole spots all say “TEST TEST” now - this was not true earlier this month. This is a very minor bug - the main thing is that it’s working!
Thank You!
George
KX0R
I pushed the fix for that a few hours back
Andrew,
Thank you - you have done an amazing job - saw your spots today!!
George
KX0R
Nice to get away from the PC for a bit and not just deal with SSO/SW3/RBNHole/newsotadata/SMP problems.
On the plus side, my 2019 goals (My 2018 - #13 by VK3ARR) have now been achieved as of mid-June - 5 new associations and half-goat ![]()
I want to say this is fixed, but every activator is being spotted and triggering the spot lockout on RBNHole, so nothing is being posted ![]()
Definitely fixed now. I’ll look at the frequency one later. Should be straightforward
Hi Andrew!
Looking very good … it can even handle two “/” in one spot
Thanks for the great work you’re doing!
73 Martin, OE5REO
Sorry Andrew …
but here is some more work for you:
When i uploaded another gps-track to SMP i noticed that the amount of summits in the list is not correct. For OE/OO it shows 445 summits but there are only 216. My guess is that all of the deleted summits are also listed in SMP!
SMP
And found this spot here today:
The frequency should have a bit less decimal points …
73 Martin, OE5REO
The frequency now has less decimal points (maximum of 4 to be precise)
This should also be fixed.
