70cm SOTA Fun Evening
Moving the discussion over here, as the other topic features “2m” in the subject field, which is unhelpful for tonight!
This evening - Tuesday 12th July 2022.
SOTA 70cm Fun Evening
Time: from 1800z (7pm BST)
Frequencies: 433.400 to 433.475MHz FM and 432.525 to 432.975MHz FM - note there will be activity down on this “all modes” segment of the band. The bulk of the FM activity will take place 1800-1855z, and from 1900z, activity will be predominantly SSB on frequencies 432.100 to 432.400MHz.
At least three, and probably more SOTA activations are expected to take place using 70cm, so there will be S2S opportunities for any additional 70cm activators, and activations for UHF chasers to seek out. The times coincide with the RSGB monthly 70cm activity contests, so good activity levels are practically guaranteed for anyone choosing to participate.
Tonight I will be paying my first visit to the chip shop @ Chapel-en-le-Frith for a SOTA sausage & chips which will be enjoyed on the summit of G/SP-001 Kinder Scout.
Hope to work a few S2S tonight.
thanks for the heads-up on the FM contest frequencies, I usually only look at the 432 section.
Hi @G1ZAR Stuart, I hope your keeping well! I haven’t seen any alerts for you yet… what time do you plan to be on summit? I am doing a small tour to try and complete 3 summits in West Wales this evening (not entering the contest), we my make a couple of S2S contacts??
73, GW4BML. Ben
I don’t often put alerts up if it’s a contest.
Should be on the summit for the start of the FM contest if traffic is good.
I don’t finish work until 1600 BST and it’s 60+ mile drive and then a fair walk up to the trig. may be online if I can get a signal (I could not last year).
It is self-spotting that is deemed “not in the spirit” of a contest. Alerting is perfectly acceptable.
Yes, in the FMACs, the vast majority of contest stations are down in the all-modes section. 144.5125 to 144.7875 for 2m and 432.525 to 432.975 for 70cm. Contest operation is tolerated in the “normal” FM frequencies on or below 433.475 from 70cm (145.400 for 2m), but most stations can be found on those lower “all modes” sections.
Thanks for the QSO Stuart. Hope you managed to keep the sausage and chips warm.
Phil.
@M1EYP @G1ZAR I was monitoring and flicking through all 70cm FM frequencies when on summit last night between 19:30 - 19:55 BST and unfortunately heard nothing. Not even one station! I advise everyone not to do the 70cm FM contest from ‘Hafod Ithel’ GW/MW-029 in the future :rofl: (I wasn’t in the contest - just thought I’d give some points away, couldn’t even do that). I had a very enjoyable time on summit though in the sun :slight_smile:
73, GW4BML. Ben
Shame I missed you Phil. I’ve noted you have a habit of kindly spotting any SOTA activators you discover in the contests. As self-spotting is not allowed if entering the contest, this is really helpful for the chasers - and of course the activator!
The contest aspect of last night was not great for me. Activity was slow, and QSB was disruptive throughout the evening. I even chucked in the towel early, going QRT around 10pm local, most unusual for me.
However, the SOTA Fun Evening aspect was excellent with a pleasing number of S2S happening.
70cm FM: 20 QSOs. 3 S2S - Simon @G7WKX/P on Easington Fell G/SP-012, Carl @GW0TQM/P on Great Orme GW/NW-070, Stuart @G1ZAR/P on Kinder Scout G/SP-001.
70cm SSB: 37 QSOs. 2 S2S - Simon @G7WKX/P on Easington Fell G/SP-012, Stuart @G1ZAR/P on Kinder Scout G/SP-001.
I believe Kirkby Moor G/LD-049 was on too, but I missed that one.
6 DXCCs: F, G, GD, GI, GM, GW
11 QRAs: IN99, IO64, 74, 81, 82, 83, 91, 92, 93, 94, 95
It’s a busy week on the contest calendar this week. Tonight it’s the 70cm FT8 and I’d normally be SOTA activating for that. However, the first 90 minutes of it is overlapped by the 80m SSB CC (club contest) so I’ll be on duty for my contest group (Tall Trees CG) from home in that, then making a token effort from the home shack in the last half-hour of the 70cm FT8 event.
I’ll be back out SOTAing tomorrow (Thursday) evening in the 6m activity contest though.
As planned, I activated G/SP-012 last night. I was a little late starting because my sat nav and I had a disagreement about where the parking was… fortunately Google Maps re-routed me onto the correct road and to the parking point to the West of the summit.
It’s about a mile from the car to the summit cairn. No trig on this one, but I still managed to find a way to wedge the metal antenna poles vertical. The antenna itself not so much, but it worked well enough.
I popped up the 40m & 20m dipole as well, in the hope of catching Fraser @MM0EFI and Ben @GW4BML but that didn’t work out this time unfortunately.
7x contacts on FM and 11x on SSB. Thanks for the S2S’s last night with Tom @M1EYP, Chris @M0KPW and Carl @GW0TQM.
I found the 70cm FM contest very quiet, so moved onto HF after about half an hour. As this summit was also in a POTA park (Forest of Bowland), I also spotted on their website which resulted in a good mix of chasers for both schemes. Best DX was probably USA and Canada on 20m @30w, or maybe Israel on 20m @6w.
I used my standard setup of the FT-818, LiFePO4 batteries, SotaBeams dipole for HF, Comet GP-3 from home for 70cm.
I should have a pass to take part next month, as Nic is away. I’ll try to start a little earlier if I can, so non-contest chasers have as much opportunity to call in as possible.
Thanks for all the contacts.
73, Simon
Hi Tom, sorry I missed you. Yes, I try to spot any activation I come across. Hopefully it drums up a bit of extra business.
I’ll be out for the 6m, so hope to catch you then.
Phil.
Hi @G7WKX Simon, sorry I missed to make a S2S with you last night. I came looking for you on 20m, but only heard the American who was working you at the time - well done on that great contact!
Fingers crossed for next time - reading your report and seeing your photo’s, looks like you had a nice evening!
73, GW4BML. Ben
Looks like summer is here. What a lovely day today. My wife Marianne and I took a drive out parking underneath Mam Tor, near Blue John Cavern. We walked up over Mam Tor and along the fine ridge to Hurst Cross. Then down into Castleton for a pastie and a pint, and finally back up the broken road (the former A625 Chapel-en-le-Frith to Sheffield main road, permanently closed in 1979 after yet another landslide).
No SOTA in that of course, but it’s the 70cm FT8AC tonight - and I’ll shortly be heading over to Gun G/SP-013 to take part. If I have spare time before the 1900z / 8pm BST start time, I’ll try my luck on 70cm CW / SSB - so any 2026 Challenge chasers may wish to watch the spots and beam my way.
Obviously I won’t be self-spotting in the FT8 contest, but given that virtually all the activity will be compressed within 432.174 to 432.177 MHz, I shouldn’t be too hard to find!
My hero. :heart_eyes:
Sked at 10pm (2100z)?
I wish I could! I hope others will pick up the mantle though!
I’ll fire up CW Skimmer then :slight_smile: - don’t expect me to be transmitting unless you want to try SSB though, could cross mode on 432.200
How did it go?
Background: considering the distance at 59km and not much in the way G/SP-013 has always been in a little bit of a blind spot so I was expecting signals to be down on comparison with nearby G/SP-015 Cloud which is always 59+ when anything but a handie with rubber duck (53 ish) is employed. Normally when chasing Gun from home on 2m FM or SSB, signals are still R5 but depending on what is being used can be S5 to S7 on average with handie with duck being down in the noise (43 ish).
I worked Tom on 70cm SSB with 59 both ways which was a pleasant surprise. After a brief chinwag which probably bored any other waiting chasers he called several more times on SSB with only 1 call which I think went uncompleted although it was just on in my background.
When Tom fired up on CW I loaded up CW skimmer. Signals were fully 599 with a good tone. Perfect copy on Toms signals with no missing characters. I should have taken a screenshot but didn’t think till afterwards. Unfortunately, I heard no replies at my end and I don’t think Tom made any qsos on 70cm CW.
This was possibly a function of not many looking at sotawatch at 10pm BST. Not sure there would have been a big pile up at any time of day though unfortunately.
Ian
Great report, thanks for that! Great job to you both. I got some 8mm x 400mm wooden sticks this week for my 2m and 70cm hourglass antenna builds. Maybe get an SSB and/or CW QSO in across the Irish Sea at some point if I am lucky!
