M0JKS
30 June 2023 15:12
1
I’ll be activating my first G/WB this weekend and will be bringing the 23cm handheld along with me - if anyone is up for a microwave QSO or S2S. I’ll be monitoring 1297.5MHz and will also spot from G/WB-006 (10 UTC), G/WB-005 (12 UTC) and G/WB-015 (14 UTC).
Dave
G6GVI
30 June 2023 15:29
2
OK Dave, I’ll have a listen for you (using horizontal polarisation).
I recall working G4VFL on 23cm from some of the WB summits, back in 2019.
G4VFL
30 June 2023 16:26
3
Here is the log extract from the activations. You may want to send an alert out to these stations by e-mail.
I am tied up ringing bells for a wedding so the only hope is G/WB-015 but from the G/LD the path profile would be very marginal to non existent.
This is the kit I use VX-6 and Sg-Lab Xverter and a few elements.
Your Summit
OtherCallsign
Band
Mode
Date
Time
Comments
G/WB-002
g3xev
1240MHz
FM
28/Jun/2019
10:58
59 / 59 John - Segley %QRA%IO82WM%
G/WB-002
g6wrw
1240MHz
FM
28/Jun/2019
11:01
57 / 58 Carolyn - Kidderminster %QRA%IO82UJ%
G/WB-002
g4jcp
1240MHz
FM
28/Jun/2019
11:04
59 / 59 Philip - Dudley %QRA%IO82WL%
G/WB-003
G3VKV
1240MHz
FM
16/Sep/2019
14:02
58 / 55 Graham - Cheltenham %QRA%IO81XV%
G/WB-003
G8GVV
1240MHz
FM
16/Sep/2019
14:09
53 / 51 Phil - Daventry %QRA%IO92KG%
G/WB-003
G4CFH
1240MHz
FM
16/Sep/2019
14:20
59 / 59 John - %QRA%IO82XO%
G/WB-004
mw1fgq
1240MHz
FM
28/Jun/2019
08:48
31 / 31 John - Holywell %QRA%IO83IG%
G/WB-004
g4cfh
1240MHz
FM
28/Jun/2019
08:49
58 / 59 John - Wolverhampton %QRA%IO82XO%
G/WB-005
G3XEV
1240MHz
FM
29/Aug/2019
14:39
G/WB-005
G6GVI
1240MHz
FM
29/Aug/2019
14:44
51 / 52 Ross - Bolton %QRA%IO83SN%
G/WB-005
G3PHA
1240MHz
FM
29/Aug/2019
14:46
53 / 52 John - Bolton %QRA%IO83SN%
G/WB-006
G3XEV
1240MHz
FM
29/Aug/2019
12:07
G/WB-006
G4BXD
1240MHz
FM
29/Aug/2019
12:09
55 / 54 Bernard - %QRA% IO82UJ%
G/WB-006
G3PHA
1240MHz
FM
29/Aug/2019
12:13
51 / 41 John - Bolton %QRA%IO83SN%
G/WB-006
G6GVI
1240MHz
FM
29/Aug/2019
12:15
56 / 54 Ross - Bolton %QRA%IO83SN%
G/WB-006
G4JCP
1240MHz
FM
29/Aug/2019
12:19
59 / 59 Philip - S. Dudley %QRA%IO82WL%
G/WB-009
G3XEV
1240MHz
FM
13/Jun/2019
11:05
G/WB-011
g3xev
1240MHz
FM
14/Jun/2019
11:49
56 / 51 John -IO82WM
G/WB-011
g6wrw
1240MHz
FM
14/Jun/2019
11:51
51 / 41 Carolyn - Kiddiminster
G/WB-012
g8xyj
1240MHz
FM
26/Jun/2019
11:58
56 / 57 Matt - Ludlow
G/WB-021
G0IUW
1240MHz
FM
13/Jun/2019
15:07
58 / 55 Roger - %QRA%IO81VR%
G/WB-024
g3xev
1240MHz
FM
25/Jun/2019
15:32
59 / 53 John - Segley %QRA%IO82WM%
73 de
Andrew G4VFL
G4AZS
30 June 2023 16:34
4
Hi Dave, I’ll be setting up for VHF NFD a few miles north west of there - not on a SOTA summit - but I’m taking my 23Cm portable kit, so will try to look out for your spots…
GL
Adrian
M0JKS
30 June 2023 16:36
5
Thanks Ross. Looking forward to making the contact if it’s possible.
Dave
M0JLA
30 June 2023 16:41
6
Seeing the number of contacts made with him in this log I should let you know that, sadly, it appears that G3XEV is SK.
Good luck,
Rod
M0JKS
30 June 2023 21:47
7
Nice setup Andrew. This will be my first adventure into microwave, so just the handheld with me this time. Maybe SSB next time when I’ve persuade the xyl I deserve a transverter.
Dave
