Hi, is it just me or did the 40m band just die?
EU sigs were ok earlier but now there is hardly a signal to be found anywhere.
73 Mike
73 Mike
In reply to GW0DSP:
I can hear a few EU stations at about S7 to S8, but they would have been S9+ earlier
73, Dave.
In reply to GW0DSP:
“Hi, is it just me or did the 40m band just die?”
Hi Mike ! No, no, you are not alone !
Here, it’s the same ! Now, I’don’t copy F6GCT/P.
Yesterday also: nothing from F6ENO/P.
I ask me: am I damned by the Ham’s Gods ??? :-))))))
73 QRO Mike,
Andy F5AKL
40M is very QSB and QRM since 2 days here also, “don’t worry”…
Chris F8DZY
In reply to F8DZY:
I think cndx not too good on 40m for 2 days but today at approx 13:30 the band just dropped out at my QTH, I think maybe a solar event?
73 Mike
In reply to GW0DSP:
Hi Mike,
Global space WX looks normal
http://www.swpc.noaa.gov/ftpdir/latest/wwv.txt
http://www.swpc.noaa.gov/ftpdir/indices/DGD.txt
Probably at that UTC you should move up in frequency to 30 m or 20 m band.
73, Jaakko OH7BF/F5VGL
In reply to F5VGL:
Thanks Jaakko, the band did seem to recover later in the afternoon, but Alain was not his usual big signal.
I think it was just a case of the skip length being much shorter than usual.
vy 73 Mike GW0DSP
In reply to GW0DSP:
From ips.gov.au:
Last updated 04 Mar 2008 17:00 UT
SUBJ: IPS PRELIMINARY HF RADIO COMMUNICATIONS WARNING 08/07
ISSUED AT 03/0302Z MARCH 2008
BY THE AUSTRALIAN SPACE FORECAST CENTRE.
DEGRADED HF PROPAGATION CONDITIONS EXPECTED
FROM 03-04 MARCH 2008
IF COMMS DIFFICULTIES EXPERIENCED TRY A LOWER FREQUENCY BAND
A MORE DETAILED HF WARNING WILL FOLLOW IF DEPRESSIONS EVENTUATE.
Aha, interesting stuff Andy, the effect at my station was very unusual today to say the least. The majority of /p stations just disappeared in an instant, even the regular big sig chasers across the EU were inaudible, just as if somebody had thrown a switch, it was that pronounced.
All part of the fascinating subject of HF propagation. The lower frequencies were superb, ie 80/60m with most sigs at 59.
As I said earlier, 40m did make a slow recovery throughout the afternoon and I was able to chase Alain F6ENO/p on his 2nd summit.
73 Mike
In reply to GW0DSP:
HF was definitely poor yesterday, I only managed to log 30 contacts on each of my 2 activations using 20/40/60/80m.
O.B.O. Steve G1INK.
In reply to GW0DSP:
Check out www.spaceweather.com - there’s a big coronal hole coming into geo-effective position so expect a few days of choppy space weather!
Here is a nice poster on how the K-index is expected to influence the propagation
http://www.interalia.plus.com/SOLAR_HO.pdf
The change in propagation could be related to the unsettled conditions of last week.
Now the days are getting longer and that is influencing also the MUF values.
