Well done Tonnie on today’s round - I hear you well on No.4 summit GW/NW-230. Going well - I hope you make your final four summits tomorrow.
73 Phil
73 Phil
Phil,
Thanks for all the calls. Vy strong signals today.
Four summits and 128 QSO’s. That’s really a lot.
It was sunny and about 0 degrees. But no problem when you hike up and down the summits.
At the third summit the only place was in te shadow. And it was vy cold. So I gave only 599 and TU. So everyone had a change to get there points.
The last summit, I arrived to late. So I made a short run. Sorry for that. When I hiked back, I missed a crossing, because it was dark. So I was a bit lost and I was an hour later at the carplace. But I made it save.
Thanks all chasers. Cu tomorrow. I will try to activate 4 summits and then going home.
73 - Tonnie - PA9CW
Last day in DM.
I activated only three summits today.
At the first summit, with a nice tower, and a picnic table. It was vy cold, about -7 degrees. I had a huge pile-up.
The second summit was a long walk. Also vy cold.
The last summit is a strange one. It’s nearby a hospital. You have to drive further for parking by the Spiegelslusturm. And then walk about 800 meters to the “summit”.
Today I made 96 QSO’s on 3 summits. It was to late to go to the last summit. It was already getting dark.
I will post my video when it’s done.
Thanks all chasers.
73 - Tonnie - PA9CW.
Again thanks all chasers. Here is my video. With 7 minutes CW sound from the KX3. Maybe you on it ![]()
Great job Tonnie on your winter DXpedition. The video in my opinion depicts a really good example of how a competent CW man handles the SOTA pile up. Although as a contester yourself I see you make use of the keyboard for sending.
So if you are reading this and you are learning the code pick up a pencil and see how many callsigns you can pick out of the pile and if you can follow what’s happening and who’s transmitting at the time.
It looks a good area to go to and not too difficult access nice summits with places to sit and to fix your antenna pole to as well.
73 Phil G4OBK
Hello Tonie,
thank you for the really nice and interesting video! I can remember these summits very well. But I could only read single letters of the CW music…
Merry Christmas and hny, 73 Lutz
Hello Tonnie, thanks for your activation video report, it is very good and great to watch. Well done and cheers to you
All the best for Xmas and a HNY to you and your family.
Regards, Geoff vk3sq
Phil,
Thanks. It sure is a nice place for SOTA. And the summits are between 500-800 meters high. And mostly good to reach. And the roads in the area, are also good. You can easily do 3 or 4 summits in the winter. In the summer even more, 5 or 6.
In a pile-up I tried to remember some calls, or parts of a call. But I do notice, that some callers can’t receive me. Or vy hard. So as an activator, you have to call a few times.
The biggest reason I use N1MM is that I can easily upload the log after all activations. And few errors can occur with transferring paper to the SOTA database. So I find it much easier.
73 - Tonnie - PA9CW
Thanks Geoff,
Good luck and cu. 73 - Tonnie - PA9CW
