I wonder if there are any VK/ZL activators who are keen / mad enough to have s2s with Europe. It’s understood that the 28 megs path opens later than 14 and that days are getting shorter down under as winter is coming. Last solar maximum, I had some SOTA contacts to VK, but these were not s2s.
Anybody fanciyng?
Yesterday, Herbert OE9HRV at OE/VB-511 worked Matt VK1MA at 08:10 UTC on 10m SSB. Sunset was 08:32 UTC.
I will be back in VK1 later next week. Wx permitting I can activate a VK1 peak in the week 18 - 24 March. Sunset will be around 08:15 UTC and last light at 08:35 UTC.
sounds great, are we commited now?
Saturday, 23rd would fit perfect for me. Maybe it’s even the best option as Saturday will probably be the day most chasers and activators would be able to join us. However I can’t see a reason why not to take a day off on 22nd.
I played a bit with VOACAP and forecast suggests that we might succeed. Or fail.
0800 - 1000 z seems best.
SSB, 50 W out on both sides. I set my antenna to 2 ele yagi 20 m agl (on a viewtower), what probably comes closest to the oblong I’ve used on 10 m since December. Assuming you would use a 5/8 lambda GP, this is the plot.
Sri, I looked up your log and saw a vk station in a log full of data qsos. Ssb is even better.
However I do not get how a qso can be completed with one station giving 11 → not readable, barely percetible signal.
Hi Pom,
WX permitting, I am planning to activate VK2/ST-053 Mt Mundoonen on Saturday 23 March as part of the 10m Challenge. Hope to catch you on summit. Alert posted.
Regards,
Al
VK1RX.
I will be staying at Mt. Hotham next weekend with a dozen or so SOTA guys. We can also be on air from a summit at this time. Maybe Mt. Loch (VK3-VE-015, 10pts)?
Seriously tempting challenge. However the forecast here is suggesting 20-37mph winds which would be a bit strong for my moxon. I’ll keep an eye on the forecast, but might give this one a miss until conditions are more favourable
Wx forecast here looks good now, dry and winds freshing up after 1000z. So, I’m gonna be on DM/NS-135. Wx permitting I will be qrv for a couple of hours.
SN currently at 141, K decreasing. What can go wrong?
