Jimmy M0HGY
M1EYP: Again, a question for which the author hasn’t yet supplied an answer. Jimmy, please name the summits you have in mind, then we’ll see if anyone else can add to that.
Jimmy M0HGY
G/LD-001 Scafell Pike
G/LD-015 Grisedale Pike
G/LD-018 Stony Cove Pike
G/LD-024 Pike of Blisco
G/NP-009 Buckden Pike
G/NP-023 Aye Gill Pike
G/NP-027 Dufton Pike
Carolyn and Helen
M1EYP: That certainly beats Jimmy’s rubbish joke. I suspect this will be the right answer. Good morning Helen & Carolyn, and welcome to this year’s Christmas Quiz.
VE7/CP-005 Mt. Dawson at longitude -117.421
Carolyn and Helen
M1EYP: Correct
In the course of his experiment to determine the density of the Earth he climbed Schiehallion, GM/SC-005, and during the survey of this mountain the concept of contour lines was born.
HC&HNY
Brian
M1EYP: Again, no answer yet put forward by the question author. The question said “two reasons”. I’m not sure if your answer is one or two reasons. Adjudication from the question contributor please…
BTW all, Jimmy M0HGY has now gone to work! He surprised me by getting on his laptop before leaving the house and answering a stack of questions. He’ll probably be on it again on his phone at lunchtime, but at least that gives everyone until around 1300 to get in on the act!
M1EYP: Correct
The only North Wales summit Carolyn needs to chase so someone go and do it please! When she is available to chase of course
M1EYP: It is one of many I have yet to activate.
Carolyn and Helen
Carolyn and Helen
M1EYP: Correct
(((WB + DC) * SC) + (NP - SP)) * CE = 2015
Might even be a way that uses them all, but life’s too short…
73 de Paul G4MD
M1EYP: That works for me Paul!
M1EYP: Yes, Mike Oldfield’s album that preceded Tubular Bells.
M1EYP: Correct.
Interesting answer, but not the person I’m thinking of. I don’t think you’ve really given two different reasons. The two reasons I’m thinking of are really quite different, but both with a SOTA connection. One connects to the S, and the other to the A.
Edit - on the Summer Solstice - should have read all the question first :-s
M1EYP: Correct, and believe it or not, this was not one of my questions. Credit for this one to G3CWI.
Err… Tom, when you emerge from the tunnel and hear him again (at the end of question 3) aren’t you F/Own Call/M ?
i.e. F/EA2CW/M under CEPT rules.
MX ES HNY … G0AZS
M1EYP: Hmm, it could easily be argued that the callsign of the driver is his callsign, as printed on his licence. He would indeed have to modify it with the extra bits if operating but HIS callsign is still EA2CW. But nonetheless, LADIES AND GENTLEMEN - we have the first successful occupant of this year’s Pedants’ Corner.
36 - GW/NW-054
Also for interest (though not Wales) W1/GM-027 and GM/SI-177. There may be others!
M1EYP: No idea, not my question. Didn’t understand it…!
SJ096716 - Sodom, Denbighshire
28 - Mount Everest - Whether it was discovered or not it was still the highest
Peter
G1FOA
M1EYP: Correct.
DM/BW-115 Kaiserstuhl/Totenkopf
DM/BW-547 Kaiserstuhl (deleted)
HB/NW-008 Chaiserstuel
OE/VB-404 Schusterstuhl (deleted)
LA/FM-007 Seilandstuva
LA/ST-268 Mørkdalstuva
So unless I am much mistaken, the question is wrong.
M1EYP: Seems that way to me too Martyn, as I cannot fault your answer.
M1EYP: I would argue that no such summit reference exists, especially given that there is no such thing as “the largest prime number”, only the largest KNOWN prime number (and none of our SOTA refs contain that for sure!). However, I think you have answered the question in the same spirit in which it was posed, and I’m confident you’ve got it right. I personally haven’t entered into the tedium of checking this, neither I suspect has the question’s author!
(Don - I’m shure Tom has tried the Green Eggs and Ham at some point :o)
Adrian G4AZS
MC & HNY to all
M1EYP: Correct.
Bolton Wanderers not currently a Premiership club. I was mybe thinking Burnley perhaps or maybe Goodison Park
M1EYP: A valid point Ian! Personally, I was thinking Swansea (which I am allowed to as I did not write this question, nor have seen the solution to it!).
Heh heh. That was my question. … You didn’t fall for the trap!
Gerald
MW0WML
