Hi Karl & all,
I passed the RAE in November 1993 (Still a Newbie really) & after receiving my pass certificate several weeks later I sent it off & eventually received my shiny new G7 call in February 1994. I first started learning Morse later in the evening after sitting the RAE. I made a very basic practice oscillator out of a couple of drawing pins, a paperclip & the musical chip from a greetings card. Fortunatlely the tune the greetings card played had a long note at the start, long enough for a dah at 5WPM. If you held the paperclip down long enough though, my first practice oscillator would actually play a tune
With lots of practice & some excellent over the air tuition from Colin G4OTN (SK) who sent the GB2CW practice Morse in my area I eventually became competent enough to apply for the 12WPM Morse test. Before sitting that test you really needed to be up to around 15WPM when relaxed to take account of nerves which do affect your speed under test conditions.
My examiner was Bill G0JWB who I already knew quite well from my local repeater group, but regardless of whether I knew Bill or not, under test conditions I did get extremely nervous. Very similar to my driving test where I thought I had made a fundamental error just after leaving the test centre. After that I thought I must have failed so I relaxed & just drove as normal. I sailed though that test
My New call G0VOF arrived just before New Years eve 1994 & in the first few years that followed I did use CW but not very much.After a bit of break form Amateur radio in the early 2000ās my interest was rekindled by SOTA & I began chasing summits more actively from about 2007 on-wards. At first I mostly used phone, & as Karl said early on in this thread, it can be frustrating when there are only CW activations showing in the spots.
Rather than get annoyed I started chasing using CW, quite slowly at first as I had pretty much forgotten most of the alphabet, but having passed the test once I thought I could pick it up again. Certainly I made mistakes, but gradually I became more proficient & thanks to many activators, who were more than happy to work chasers who may not be able to send at their speed, I did improve.
Now, I am pretty confident at any reasonable speed for short SOTA type QSOās & as a consequence I am now getting better at rag-chewing at a speed that means I am not asking the other station to slow down. In my experience, with CW once you reach a certain speed something just clicks in your brain & everything becomes clear. For me that happened at around 26WPM but for others that may be faster or slower.
In any case, I am now appreciating CW in the way old-timers told me about when I was first starting out.
Would I recommend CW to other amateurs? Yes.
Would I expect other amateurs to use CW to satisfy my need for chaser points? No.
An activator can use whatever mode / band they want & if I have the equipment & ability to use that mode / band I will have a go at chasing them.
If I donāt have that capability, then, like fishing, it will be one that got away.
I donāt see myself as a CW evangelist, although I do love the mode. I would no sooner ask Mike 2E0YYY to use CW than I would ask Gerald F6HBI to use SSB. Each activator has his / her preferred mode & as chasers we have to accept that. If they use a band / mode you cannot use, then see that as a challenge to improve your station / capability.
At the end of the day, SOTA, & amateur radio is what you make it yourself.
Enjoy it, I certainly do.
Thanks & best 73,
Mark G0VOF
