This mad person planned for a long activation on Saturday 17th January 2015, incorporating the 4 hour RSGB AFS contest event. As it was the SSB event, I would be participating while combining with a SOTA activation so as to leave the home shack free for Jimmy M0HGY to contribute a further entry on behalf of the Tall Trees Contest Group.
Essential preparations of a flask of mulligatawny soup, purchase of a new SOTA Pole and donning of thick socks, I was off and away around 12:45pm. Ascent of The Cloud G/SP-015 was the slightly longer way around of up to the top of the farm track, then around the back of the farm and through the woods. I baggsed my preferred spot on the sheltered side of the topograph and set up the Bandhopper 4 linked dipole antenna.
The RSGB AFS SSB event this year was to be on 80m and 40m, rather than just 80m, hence the multiband option was taken. Fortunately, the only link needed to be accessed was just about reachable without taking down the antenna.
I was set up with a few minutes to spare, so I went for a nosy on the WAB net frequency of 7.160MHz SSB. I went on to offer the SJ96 square, and of course the trigpoint. I hadn’t planned this, so didn’t have the TP number to hand. No problem I thought, I’ll just get it off the trigpoint. I wandered over and made a note of the 2651 from the metal plate. It turns out that the TP references do not correlate with the metal plates, and “TP2651” is somewhere completely different! I found out later that The Cloud is TP6366; hopefully the guys on the net had enough other information to identify the correct trig.
Anyway, I quickly ran down 16 stations on the WAB net, then turned my attentions to the contest. In this, I did two sessions each on 80m and 40m, netting a total of 110 QSOs - after dupes had been eliminated! I discovered it is quite hard to spot the dupes when logging with pencil and paper (as opposed to contest software) on a hilltop at -1 degrees Celcius!
After 1600z, I spotted myself on 3.645MHz for any SOTA chasers, but only a couple took advantage. I noticed that I hadn’t worked Jimmy M0HGY in the contest, so arranged a 2m FM contact with him while on the 'phone finding out what the arrangements were for tea! Several others also called in on two.
The totals for the activation were as follows:
80m: 59 QSOs
40m: 70 QSOs
2m: 6 QSOs
Total: 135 QSOs
So in 2015 I am averaging 85 QSOs per activation. I must remind myself that I only need 4…
