LA1KHA
22 January 2011 02:33
41
Stats:21/01/2011
Battery: #3
Activation: #8
Summit: LA/TM-049
Band: 30m
Finish:8.25 TEMP -5C
QSOs: 6
DXCCs:4 DL,G,HA,LA
Cumulative QSOs: 73
Cumulative DXCC: 16 (DL,EA,F,G,GI,GM,HA,I,HB9,OE,OK,OM,LA,PA,S5,9A )
Se also http://www.sotawatch.org/reflector.php?topic=3597#foot
73 de LA1KHA
LA1ENA
22 January 2011 23:02
42
In reply to LA1KHA:
Battery: #1
BATTERY: Panasonic Xtreme power
Activation: #2
Summit: LA/TM-049
Band: 30m
Finish Voltage: 8,69
QSOs: 10
DXCCs: 5 (DL,G,HB9,ON)
Cumulative QSOs: 19
Cumulative DXCC: 5 (G,PA,UA2,GW,DL,HB9,ON)
73 de Aage
LA1KHA
23 January 2011 00:54
43
Stats:22/01/2011
Battery: #3 Philips Extreme life
Activation: #9
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 10
DXCCs:7 DL,G,HA,HB9,I,LA,PA
Cumulative QSOs: 83
73 de LA1KHA Kjell
LA1KHA
24 January 2011 03:26
44
Stats:23/01/2011
Activation: #10
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 13
DXCCs:10 DL,G,HA,I,LA,OE,ON,OK,S5, SP
Cumulative QSOs: 96
Cumulative DXCC: 18 (DL,EA,F,G,GI,GM,HA,I,HB9,OE,OK,ON,OM,LA,PA,S5,SP,9A )
73 de LA1KHA
LA1KHA
25 January 2011 00:40
45
Stats:24/01/2011
Activation: #11
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 7
DXCCs:6 G,HA,I,LA,S5, UR
Cumulative QSOs: 103
Cumulative DXCC: 19 (DL,EA,F,G,GI,GM,HA,I,HB9,OE,OK,ON,OM,LA,PA,S5,SP,UR,9A )
73 de LA1KHA
LA1KHA
26 January 2011 03:01
46
Stats:25/01/2011
Activation: #12
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 8
DXCCs:6 F,DL,G,HA,HB9,LA
Cumulative QSOs: 111
73 de LA1KHA
LA1KHA
26 January 2011 21:42
47
Stats:26/01/2011
Activation: #13
Summit: LA/TM-049
Band: 30m
Finish:8.12V @-10c
QSOs: 9
DXCCs:6 ,DL,G,HA,OE,LA,UA
Cumulative QSOs: 120
Cumulative DXCC: 20
(DL,EA,F,G,GI,GM,HA,I,HB9,OE,OK,ON,OM,LA,PA,S5,SP,UA,UR,9A )
73 de LA1KHA
LA1KHA
28 January 2011 23:42
48
Stats:28/01/2011
Activation: #14
Summit: LA/TM-049
Band: 30m
Finish:8.10V @-9c
QSOs: 8
DXCCs:5 ,DL,HA,LA,LZ,S5
Cumulative QSOs: 128
Cumulative DXCC: 21
(DL,EA,F,G,GI,GM,HA,I,HB9,OE,OK,ON,OM,LA,LZ,PA,S5,SP,UA,UR,9A )
73 de LA1KHA
LA1KHA
30 January 2011 08:03
49
Stats:29/01/2011
Activation: #15
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 5
DXCCs:5 ,G,HA,OE,LA,S5
Cumulative QSOs: 133
Cumulative DXCC: 21
73 de LA1KHA Kjell
G3CWI
30 January 2011 18:10
50
In reply to LA1KHA:
Battery: #1
Activation: #12
Summit: G/SP-013
Band: 30m
Finish Voltage at room temp: 8.4V
QSOs: 9
DXCCs: 7 (G, HA, DK, EA, OZ, SP, OK)
Cumulative QSOs: 124
Cumulative DXCCs: 16 (ON, S5, OK, G, DK, I, LA, F, OE, HB9, HA, SM, 9A, EV, EA, OZ)
Current Records:
LA1KHA: Batt#1 51Q: Batt#2 150Q - WORLD RECORD : Batt#3 133Q
LA1ENA: Batt#1 19Q
G3CWI: Batt#1 124Q
Pretty amazing for a 9V battery. As far as I’m aware every activation has been a success. The secret ingredient is use of SOTAwatch and the SMSbot plus supportive chasers. Thanks!
Richard
G3CWI
LA1ENA
30 January 2011 22:26
51
In reply to G3CWI:
Battery: #1
Activation: #3
Summit: LA/TM-015
Band: 30m
Finish Voltage: 8,73
QSOs: 8
DXCCs: 5 (G,DL,F,OK,PA)
Cumulative QSOs: 27
Cumulative DXCC: 8 (G,PA,UA2,GW,DL,HB9,ON,OK)
73 de Aage
LA1KHA
1 February 2011 01:48
52
Stats:30/01/2011
Activation: #16
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 5
DXCCs:3 DL,G,OE,
Cumulative QSOs: 138
Cumulative DXCC: 21
73 de LA1KHA Kjell
LA1KHA
1 February 2011 01:52
53
Stats:31/01/2011
Activation: #17
Summit: LA/TM-049
Band: 30m
Finish: 7.98V@-3C
QSOs: 8
DXCCs:7 DL,F,G,HA,HB9,OK,LA
Cumulative QSOs: 146
Cumulative DXCC: 21
73 de LA1KHA Kjell
G3CWI
1 February 2011 22:51
54
In reply to LA1KHA:
Looks like a new record is within reach for you Kjell with battery #3 . I am progressing with my new design. So far the first mixer/oscillator is complete (2.2mA). If all goes well I should be able to make a complete superhet with high performance ladder crystal filters that will take around 7mA. I may take on your suggestion and reduce the TX power a bit from my current 300mW to about 150mW. I suspect that will take quite a bit of experimenting to get right. In theory I should be able to get the TX current down below 50mA at that level. That would allow many hours of operating from a PP3. Is 300 QSOs possible?
Richard
G3CWI
LA1KHA
2 February 2011 02:01
55
Tanks for info G3CWI Richard. I think your low power TRX would be most successful.This rig would be a real Rockmite killer.
My plan is to go other way around.Even cruder design with less power and with near 0 in RX performance.
With present setup I do not believe that it is possible to do more than 160-165 QSO Battery at 7.9v now,output is now decreasing .I tested the rig to 70mW@8v.
Stats:01/02/2011
Activation: #18
Summit: LA/TM-049
Band: 30m
Finish: 7.90V@+1C
QSOs: 4
DXCCs:4 HA,I, LA,OE
Cumulative QSOs: 150
Cumulative DXCC: 21
73 de LA1KHA Kjell
LA1KHA
3 February 2011 09:14
56
Stats:02/02/2011
Activation: #19
Summit: LA/TM-049
Band: 30m
Finish: 7.88V@+2C
QSOs: 5
DXCCs:5 F,HA LA,OE,OK
Cumulative QSOs: 155
Cumulative DXCC: 21
73 de LA1KHA Kjell
LA1KHA
5 February 2011 02:52
57
Stats:04/02/2011
Activation: #20
Summit: LA/TM-049
Band: 30m
Finish: 7.85V@+1C
QSOs: 13
DXCCs:8 DL,EW,HA,LA,OE,OM,UA,S5
Cumulative QSOs: 168
Cumulative DXCC: 22
(DL,EA,EW,F,G,GI,GM,HA,I,HB9,OE,OK,ON,OM,LA,LZ,PA,S5,SP,UA,UR,9A )
73 de LA1KHA Kjell
LA1KHA
6 February 2011 13:14
58
Stats:06/02/2011
Activation: #22
Summit: LA/TM-049
Band: 30m
Finish:
QSOs: 7
DXCCs:5 DL,F,G,HA,OE,
Cumulative QSOs: 178
Cumulative DXCC: 22
73 de LA1KHA Kjell
6 February 2011 23:29
59
In reply to LA1KHA:
It’s time to start taking bets on whether Kjell will get 200+ qsos from a single battery.
LA1KHA
8 February 2011 01:17
60
MM0FMF Andy. I wouldn’t bet to high on 200+QSO. But if I am lucky It can happens. Output are low now. <70mW Today I wasted lots of mAH on calling cq. 10.120 was so crowded so I waited some time and when silent on frq no one come back to my calls. The WX was -1c snowing/ nearly rain. some +5cm while I was up on the summit.
Stats:07/02/2011
Activation: #23
Summit: LA/TM-049
Band: 30m
Finish:7.72v@-1c
QSOs: 4
DXCCs:4 F,G,HA,LA,
Cumulative QSOs: 182
Cumulative DXCC: 22
73 de LA1KHA Kjell
