You’re totally missing the point. The older sites got this matter right. It is the shiny new site that gives the wrong answers.
But yes, I’m a fool. Only last night I remarked the Caroline (and she can witness): “We should report this privately - they’ll take the hump if we post publicly”. I only posted here because it was actually relevant to an existing thread.
I’m a little confused here Esther, so please forgive what may be a stupid or impertinent question - I’ve found, by digging around a little, some activations in New Zealand, between March 5th 2017 and March 19th 2017, where both you and Ian are logged as having activated. Do you mean to say neither of you were there at the time?
Of course I’m missing the point, Martyn, when it comes to computers I’m barely one step above a total idiot - I used to be much happier with making a circular slide rule dance, though you couldn’t get chatty on them! Believe me, if I didn’t have to wear the famous moderator’s hat with the spike on top I would never even have bothered to read this thread, but I have to read them all, no escape, and I reacted to the pattern of public complaints that had become too familiar. Perhaps I’ve got cabin fever, too!
Everyone stop! The upcoming SSO changes will fix all this. These things take time, hopefully a preview for all might be available after I get back from Korea in two weeks time.
Rob’s SOTAMaps is obviously benefitting from some of the work already. Not everything else is in a state yet to do so.
Sotamaps is benefitting in large part from my having put in substantial effort over the past year or so to figure out how to pull the right data from (a copy of) the same data sources as are available to your MT team.
Apart from having access to these data sources (for which, as a 3rd-party developer far removed from the MT, I am of course immensely grateful), I’ve not seen hide nor hair of any of the work you mention, although I understand you currently have a team of people testing the new sites.
The problems highlighted by Esther GI0AZA are easily fixed and, as Martyn M1MAJ points out, should never have depended upon people having to list their alternative callsigns. In any case
…and as Brian pointed out, continually pointing out that our old systems are old doesn’t make them newer any more quickly. The issue is not desire or will but the fact this is a volunteer organisation that relies on people’s time and goodwill for anything to progress.
So yes, it shouldn’t have depended on the alternative callsigns, did at the time because it had to, now needs rewriting, rewriting is happening, will be coming. We’re aware, no need to bring it up again.
Well, to tell the truth, since I no longer use any of the SOTA sites or services, old or new (having personally given up on both SOTA and ham radio), I actually had no idea which of them Esther was referring to.
My interest in this thread was piqued by Andy’s amusing retort to Esther’s somewhat vague reporting of the issue she had noticed, and then by Martyn’s subsequent comment. And it just ballooned, as these things so often do…
Okey, dokey, chief, thanks for clearing up any misunderstandings!
No effect is good, Rob. Be afraid of counter effects. Here is a story.
A few months ago, I publicly (through this reflector: 1st August 2018 Association updates - #10 by E70AA) pointed out to discrepancy in the winter bonus data for E7: the E7 RM said that one can get winter bonus for activating summits higher than 1000m, while the database and consequently sotamaps had that value set to 1400m (I think no country in Europe has the winter bonus altitude set so high).
OC Brian suggested that I inform the MT guys about this issue using the PM mechanism since that should produce a better and more timely solution to the issue. So, I did as I’d been instructed and soon I got response from MT member Simon (G4TJC). In a note (that even Sheldon from Big Bang Theory would easily recognized as sarcasm), Simon thanked me for pointing out to the discrepancy and promised to resolve the issue by “correcting” the value in the E7 RM! Which he did. Now, it is 1400m all over.
Isn’t that a great way to solve a problem or what?
Well, Simon is an astronomer, his head is in the clouds, so to speak: so it’s probably not surprising that he chose the higher of the two altitudes! Nonetheless, you and your Slovenian colleagues can take solace in the idea that, since the winter bonus altitude is set so high in your country, it must reflect the high degree of fitness and toughness of the Slovenian people
But, yes: i do take your point; it’s often better to let sleeping dogs lie undisturbed.
You asked us to correct the inconsistency between ARM and DB. This is what I did, with the ARM now correctly reflecting the reality of the bonus points assigned by the DB. You did not ask us to reduce the WB elevation level on the DB.
Since you are discussing my reply, here it is:
Thank you for bringing this to our attention.
The ARM is being updated to match the database.
Regards,
Simon, G4TJC
Apparently you saw that as funny. In any case I received no reply, so presumed the matter was resolved. Perhaps a theoretical physicist would be able better to construct withering sarcasm even in such a short note but for a me it was a simple note of the actions we were taking.
The MT is guided by the AM on winter bonus issues. So if you think the bonus elevation for E7 is not appropriate please petition your AM, Žaro @E73DU, and if he agrees he can discuss it with us.
Well, those are my words, Phil! - I must admit to being a little out of touch with ham radio and prefixes and what-not these days. But the fact that Zoran did not correct my silly mistake is surely a tribute to a high degree of empathy, tolerance and good humour on his part.
As you might know, for a large part of the twentieth century, Bosnia and Slovenia were parts of the same country. Since Slovenians were by far the most dedicated mountain lovers in the country, Bosnian people with similar affinity were often called “Slovenians”. So, hey, Rob wasn’t so wrong after all
