Winter Bonus on Snowdon
What a great way to start the season. I had not planned to visit GW/NW-001 until yesterday, when it became clear that the weather was likely to be tolerably good.
Everything went well; no traffic hold ups, and 2 hours 15 mins walk to the top, exactly as my last visit 18 months ago. This time, I wasn’t pushing, and didn’t feel bushed, so I guess the SOTA activating has improved my fitness. Good news for an old codger! None of my contingency time was used, so I was on summit well ahead of the alerted time.
Above about 600m, I was into murky cloud. But for the final 100m or so, the air was clear, and I was walking in bright sunlight, looking out over the cloud base. Breathtaking.
10 mins later, and I was enveloped in cloud again, which slowly thickened throughout the activation.
With very few people around, I was able to set up the VHF antenna just below the highest point, and made a nice run of contacts including 6 S2S - plenty of others out enjoying the first day of Winter :o)
On my last visit, people were jostling for space to sit down like gannets on a rocky island. This time I was able to set up a 40m dipole without anyone noticing. A quick dabble on 5MHz produced a pleasing run of contacts, followed by some more on 7MHz SSB. Running a nominal 5W from the FT817, using just the internal batteries.
I intended to visit 10MHz CW, but after almost 2 hours on the summit, and in wet cloud, I decided it was time to leave.
Many thanks to all contacts, much appreciated.
I took a few photos with my phone, as usual, but they don’t really do it justice:
Adrian
G4AZS
Nice to work you on 5MHz, what did you use for an antenna on 60m?
Nice photos.
Colin G8TMV
Hi Colin, I used the 40m dipole, together with an Elecraft auto tuner. Actually, it is a 30m dipole, which I extended with a couple of bits of wire whilst on a summit earlier in the year. I just paced out the length, so I’m not sure how accurate it is :o)
It was rigged on a 5m pole, and has about 1.5m of insulating line on each end. I tried to get the ends clear of the ground by using rocky outcrops…
Adrian
Lovely report and photos
PS thanks for ones 10 points today also
did find 40m was being a little pain today
Karl
Hi Adrian
Many thanks for the s2s today on 2m - much appreciated. Really great that you were able to get on HF from there and thanks for sharing the spec of your set up - food for thought.
Thanks to all the other activators who made it into my log.
Allan GW4VPX
